Solve x: Calculus Natural Log Homework Statement
The discussion revolves around solving the equation ln(3x+1) = 3 - lnx, which is situated within the context of calculus and logarithmic functions. Participants are attempting to isolate x and explore various algebraic manipulations to arrive at a solution.
  • Mixed
  • Participants discuss different algebraic steps taken to manipulate the logarithmic equation, including combining logarithms and applying the exponential function. There are questions about the validity of dividing by x and the implications of such operations on the final answer. Some participants also explore the use of the quadratic formula and the conditions under which solutions are valid.
The discussion is ongoing, with participants providing feedback on each other's approaches and identifying potential errors in reasoning. There is a recognition of the importance of the domain of the logarithmic functions involved, and some participants suggest that only one of the solutions derived from the quadratic formula may be valid.
There are indications of confusion regarding the application of algebraic rules, particularly in relation to the manipulation of radicals and the implications of the quadratic formula. Participants are also navigating the constraints of the original equation, which requires that x must be positive for the logarithmic expressions to be defined.
Ericalvusa91
ln(3x+1) = 3-lnx
Solve for x
Well I put the ln on the left side
ln(3x+1)+ln(x) = 3
Then I combine them
ln ((3x+1)(x)) = 3
So I take e
e^ln(x(3x+1)) = e^3
I get x(3x+1) = e^3
So I divide the x
(3x+1)/(x) = (e^3)/(x)
Multiply x by both sides
3x+1 = e^3
Subtract the 1
3x = (e^3)-1
Divide by 3
x = ((e^3)-1)/3
Can someone tell me if I made a mistake or did it totally wrong ?
Ericalvusa91 said:
I get x(3x+1) = e^3
So I divide the x
When you divide by x, you should get 3x+1 = e3x-1. This is different than what you show and it should have an impact on the final answer.
So I did what you said.
3x+1 = e^3 x^-1
3x-x^(-1) +1 =e^3
factor out x(3-1^(-1))=e^3
Divide both sides by 3-1^(-1)
ans: (e^3)/ 2 But I still get it wrong
Ericalvusa91 said:
3x-x^(-1) +1 =e^3
How did you get this? It doesn't follow from the equality you had before this.
I subtracted the x^-1
You can't subtract it out like that. Remember that it's multiplied to e3. If you're not familiar with this, you should probably review your elementary algebra.
Anyway, before this goes further, the approach that you're taking (dividing through by x) doesn't really work. You should be able to get the equation 3x2+x-e3 = 0 and then solve for x.
I suppose I use the quadratic formula but I'm only suppose to get one answer
I get (sqrt (12e^3))/(6) and -(sqrt (12e^3))/(3)
Think about which of those values make sense for log(x). The domain of the functions involved is very important.
Yes, use the quadratic formula. Since your first equation has ln(3x + 1) and ln(x), x must be positive, which will probably eliminate one of the solutions you get from the quadratic formula.
Nope the positive value is wrong too
That would be because you applied the quadratic formula incorrectly.
Just to be sure c would be -e^3 right?
That's correct.
Heres what i Have
3x^2+x-e^3=0
-b+-√((b^2) - 4ac)/2a
-1+-√(1^2)-4(3)(-e^3))/2(3)
-1+-√(1+12e^3)/6
Then two possibilities but only need the positive value
1st possibility = -1+1+√(12e^3)/6 = √(12e^3) / 6
You still have a mistake. If 3x^2 + x - e^3 = 0,
then
[tex]x = \frac{-1 \pm \sqrt{1 + 12e^3}}{6}[/tex]
One of these values is positive and the other is negative.
The second value is (-1/3)+√(12e^3)/(6) so should I find the lcd
How are you getting that?
You have 1 + 12e^3 in the radical, and there's no way you can simplify that.
I thought you can take the radical one
-1-√(1+12e^3)/6
I still get it wrong though
The two solutions to the quadratic equation are
x1 = [-1 + √(1+12e^3)]/6
and x = [-1 - √(1+12e^3)]/6
The first one above is positive; the second one is negative.
I don't know what you mean by this:
I thought I could separate √(1) and √12e^3.
Those x-values do not give me the right answer unless I am suppose to do something after that. However, if I already solved for x it should be the answer though right?
Are you thinking that √(a + b) = √a + √b? That is not true.
Why do you think that those values are incorrect? (Only one works in your original equation, though.)
The positive value should make your original equation a true statement. If so, then you're done.
Thank You. I finally got it! Instead of putting the -1 divided by 6, I left it as whole number 1.
  • · Replies 25 ·
