Solve x: Calculus Natural Log Homework Statement
In summary: I thought that if I did that then the radical would cancel out and I would only get one solution. However, that didn't work and I had to go back and try again.
Ericalvusa91
ln(3x+1) = 3-lnx
Solve for x
Well I put the ln on the left side
ln(3x+1)+ln(x) = 3
Then I combine them
ln ((3x+1)(x)) = 3
So I take e
e^ln(x(3x+1)) = e^3
I get x(3x+1) = e^3
So I divide the x
(3x+1)/(x) = (e^3)/(x)
Multiply x by both sides
3x+1 = e^3
Subtract the 1
3x = (e^3)-1
Divide by 3
x = ((e^3)-1)/3
Can someone tell me if I made a mistake or did it totally wrong ?
Ericalvusa91 said:
I get x(3x+1) = e^3
So I divide the x
When you divide by x, you should get 3x+1 = e3x-1. This is different than what you show and it should have an impact on the final answer.
So I did what you said.
3x+1 = e^3 x^-1
3x-x^(-1) +1 =e^3
factor out x(3-1^(-1))=e^3
Divide both sides by 3-1^(-1)
ans: (e^3)/ 2 But I still get it wrong
Ericalvusa91 said:
3x-x^(-1) +1 =e^3
How did you get this? It doesn't follow from the equality you had before this.
I subtracted the x^-1
You can't subtract it out like that. Remember that it's multiplied to e3. If you're not familiar with this, you should probably review your elementary algebra.
Anyway, before this goes further, the approach that you're taking (dividing through by x) doesn't really work. You should be able to get the equation 3x2+x-e3 = 0 and then solve for x.
I suppose I use the quadratic formula but I'm only suppose to get one answer
I get (sqrt (12e^3))/(6) and -(sqrt (12e^3))/(3)
Think about which of those values make sense for log(x). The domain of the functions involved is very important.
Yes, use the quadratic formula. Since your first equation has ln(3x + 1) and ln(x), x must be positive, which will probably eliminate one of the solutions you get from the quadratic formula.
Nope the positive value is wrong too
That would be because you applied the quadratic formula incorrectly.
Just to be sure c would be -e^3 right?
That's correct.
Heres what i Have
3x^2+x-e^3=0
-b+-√((b^2) - 4ac)/2a
-1+-√(1^2)-4(3)(-e^3))/2(3)
-1+-√(1+12e^3)/6
Then two possibilities but only need the positive value
1st possibility = -1+1+√(12e^3)/6 = √(12e^3) / 6
You still have a mistake. If 3x^2 + x - e^3 = 0,
then
[tex]x = \frac{-1 \pm \sqrt{1 + 12e^3}}{6}[/tex]
One of these values is positive and the other is negative.
The second value is (-1/3)+√(12e^3)/(6) so should I find the lcd
How are you getting that?
You have 1 + 12e^3 in the radical, and there's no way you can simplify that.
I thought you can take the radical one
-1-√(1+12e^3)/6
I still get it wrong though
The two solutions to the quadratic equation are
x1 = [-1 + √(1+12e^3)]/6
and x = [-1 - √(1+12e^3)]/6
The first one above is positive; the second one is negative.
I don't know what you mean by this:
I thought I could separate √(1) and √12e^3.
Those x-values do not give me the right answer unless I am suppose to do something after that. However, if I already solved for x it should be the answer though right?
Are you thinking that √(a + b) = √a + √b? That is not true.
Why do you think that those values are incorrect? (Only one works in your original equation, though.)
The positive value should make your original equation a true statement. If so, then you're done.
Thank You. I finally got it! Instead of putting the -1 divided by 6, I left it as whole number 1.
Related to Solve x: Calculus Natural Log Homework Statement
1. What is the natural log function in calculus?
The natural log function in calculus is the inverse of the exponential function. It is denoted as ln(x) and represents the power to which the base number e (approximately 2.71828) must be raised to equal the given number x. In other words, ln(x) = y means that e^y = x.
2. How do I solve for x using natural logs in calculus?
To solve for x using natural logs in calculus, you can use the properties of logarithms and exponential functions. First, isolate the logarithmic term by moving any other terms to the other side of the equation. Then, use the property of logarithms that states ln(x^a) = a*ln(x) to rewrite the equation. Finally, solve for x by taking the exponential of both sides.
3. What are the common rules for using natural logs in calculus?
The common rules for using natural logs in calculus include the product rule (ln(ab) = ln(a) + ln(b)), quotient rule (ln(a/b) = ln(a) - ln(b)), and power rule (ln(a^b) = b*ln(a)). In addition, the natural log of the base number e is always equal to 1, and the natural log of 1 is equal to 0.
4. Can natural logs be used in both differentiation and integration?
Yes, natural logs can be used in both differentiation and integration. In differentiation, the derivative of ln(x) is 1/x, and in integration, the integral of 1/x is ln(x) + C. These relationships are a result of the inverse relationship between the natural log function and the exponential function.
5. How do I apply natural logs in real-world problems?
Natural logs can be useful in solving real-world problems involving exponential growth or decay. For example, natural logs can be used to model population growth, radioactive decay, and compound interest. In these scenarios, the natural log function can help determine the rate of change over time and the final amount after a certain period.
