Solving a definite integral without using gamma function
5 replies · 2K views · last reply
Saitama
Problem:
Evaluate:
$$\int_0^{\infty} t^{-1/4}e^{-t}\,dt$$
Attempt:
I recognised this one as $\Gamma(3/4)$. I found a few formulas on Wolfram Mathworld website which helps to evaluate this but I am wondering if I can solve the definite integral from elementary methods (like by parts).
Any help is appreciated. Thanks!
This integral cannot be solved using elementary methods because the result is only representable using the gamma function
$$\Gamma(x) = \int^\infty_0 t^{x-1}\, e^{-t} \, dt$$
and cannot be introduced otherwise. The result can be written differently using some properties of the gamma function. For example ,
$$\Gamma(x) \Gamma(1-x) = \pi \csc(\pi x) $$
$$2^{1-2x}\sqrt{\pi}\Gamma(2x) = \Gamma\left( x+\frac{1}{2}\right) \Gamma(x) $$
$$\Gamma(1+x) = x \Gamma(x)$$
Thanks ZaidAlyafey! :)
Is there a proof for the following formula?
I am actually dealing with the product $\Gamma(3/4)\Gamma(1/2)\Gamma(1/4)$. If I use the above formula, I can easily find the value of the product.
The proof is a pain. The one I saw used relatively large amount of differential galois applied to gamma values.
The proof that uses less formulas and easiest , in my opinion, is using complex analysis.
Its better that I stay away from the proof. :p
Thanks, I solved the problem using the formula. :)
