Solving a Differential Eq using Laplace and Unit-Step function
10 replies · 6K views · last reply
Saladsamurai
!Solving a Differential Eq using Laplace and Unit-Step function
I am having a terrible time just starting this. I need some explanation here. I have given up on the text I am using...
I need to solve the following piecewise function using Laplace and Unit-Step function:
y"+4y=f(t) y(0)=-1, y'(0)=0
where f(t)= t, t<2
5, t>2
Now I condensed it to one line using the Unit Step function giving:
[itex]y''+4y=t-t*U(t-2)+5*U(t-2)[/itex]
Applying Laplace to the LHS is easy enough, but what is the Laplace of the unit step function? I am having a hard tome extrapolating it from the text.
So far I have
[itex]s^2Y(s)-sy(0)-y'(0)+4Y(s)=\frac{1}{s^2}-?[/itex]
Could somebody help me out with the "U" terms here?
Thank you
SKIP AHEAD TO POST #10 That is where I need help
Can somebody please help me with the Laplace Transform
[tex]L(-t*U(t-2))[/tex]
I cannot figure this out!
Is this even "Laplacable"? I guess I do not understand the rules
Since the U(t-2) just changes the limits of integration to 2 to infinity, rather than 0 to infinity, you need to change the variable from x to u= x- 2 to get back the 0 limit.
Doing that gives a general rule that the Laplace transform of f(x)U(x-a) is e-asF(s) where F(s) is the Laplace transform of f(x).
So for [itex]-t*U(t-2)[/itex] I should get [itex]e^{-2s}*-\frac{1}{s^2}[/itex]?
Halls, I just found this in my text as a side note. It would appear that the Laplace of f(t)*U(t-a)=e^{-as}*L{g(t+a)} ... not just +L{g(t)}
Okay so I have got it down to this point:
[tex]Y(s)[s^2+4]=\frac{1}{s^2}-e^{-2s}*\frac{1}{(s+2)^2}+5e^{-2s}*\frac{1}{s+2}-s[/tex]
I was going to write the RHS over the LCD and then divide out by [s^2+4] ...sound good? ... there must be a neater way to so this... isn't there? This looks like it will get very sloppy very quick!
