Solving a Lightning Storm Homework Problem
vdeity
A certain storm cloud has a potential of 1.50 x 10^8 V relative to a tree. If, during a lightning storm, 50.0 C of charge is transferred through this potential difference and 1.00% of the energy is absorbed by the tree, how much sap in the tree can be boiled away? Model the sap as water initially at 26.0°C. Water has a specific heat of 4186 J/(kg·C°), a boiling point of 100°C, and a latent heat of vaporization of 2.26 x 10^6 J/kg.
I'm actually kinda iffy on all the equations, but I got several answers that WebAssign told me was wrong...
Energy gain of 50.0 C of charge accelerated through potential difference of (1.50 x 10^8 V) is (50.0 C)(1.50 x 10^8 V) = 7.5 x 10^9 J.
To vaporize 1 kilogram of sap requires mcΔT = (1 kg)(4186 J/kg K)(100 - 26 degrees C) = 3.098 x 10^(5) J to heat to 100 degrees C
An additional 2.26 x 10^6 J for the state change from liquid to gas, for a total required energy of 3.098 x 10^(5) + 2.26 x 10^6 = 2.57 x 10^6 J.
The total energy absorbed is 1% of 7.5 x 10^9 = 7.5 x 10^7 J, and at 2.57 x 10^6 J per kg needed, we are able to vaporize:
(7.5 x 10^7 J)/(2.57 x 10^6 J/kg) = 29.19 kg of sap.
WebAssign says it's wrong.
Please tell me where I went wrong.
It isn't due for a few days, I just wanted to get this assignment out of the way... Last question.
Thanks!
WebAssign is evil. I see nothing wrong with your solution - your method is OK and I verified your numbers. It may be a matter of sig figs or (perish the thought) the wrong calculated formula has been put into the problem. I suggest that you take your solution to your instructor and ask him/her to find what is wrong with it. Do this before the deadline.
Sorry to bring up an old thread, but I was under the impression that the energy absorbed by the tree will be equal to 1/2QV, and not QV. I'd be curious to hear what others have to say about this.
Thanks,
Tom
That would be true if you had a capacitor with 50C on it that you let completely discharge.
The question doesn't say that the stormcloud completely discharges however.
I see what you're saying. Thanks.
##|\Psi|^2=\frac{1}{\sqrt{\pi b^2}}\exp(\frac{-(x-x_0)^2}{b^2}).## ##\braket{x}=\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dx\,x\exp(-\frac{(x-x_0)^2}{b^2}).## ##y=x-x_0 \quad x=y+x_0 \quad dy=dx.## The boundaries remain infinite, I believe. ##\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dy(y+x_0)\exp(\frac{-y^2}{b^2}).## ##\frac{2}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,y\exp(\frac{-y^2}{b^2})+\frac{2x_0}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,\exp(-\frac{y^2}{b^2}).## I then resolved the two...
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
