Solving a linear homogenous 2nd order DE with a constant term
bitrex
I know how to go about solving differential equations of the form y''+q(x)y'+t(x)y = 0 through the methods of finding the characteristic polynomial of the differential equation and solving for the roots, etc. But what I am not clear on is how I would go about solving an equation like this where one of the terms is a constant, such as y''+q(x)y' + C = 0 or y'' +t(x)y + C = 0. I'm thinking of a situation with an F=ma equation where there is a term that is dependent on the position or velocity of an object, but there is also something like a gravitational force, which is constant.
Do you mean that your q(x) and t(x) are constants? The method you described doesn't work if they are not constants. If you simply have a constant or some term that doesn't have y,y', or y'', your equation is simply inhomogeneous. You tack on a particular solution that depends on what the inhomogeneous part is. If you have a inhomogeneous part, the full solution is simply y(x) = y_c + y_p where y_c is the solution to the homogeneous equation and y_p is the solution to the inhomogeneous equation. For a constant inhomogeneous part, you try y_p = C where C is a constant. You plug this into the DE and solve for it. If the solution for your homogeneous equation is a constant, you can't use that for a particular solution. You can try y_p = Ax + B and solve for A and B to form your solution.
Thread 'Direction Fields and Isoclines'
I sketched the isoclines for $$ m=-1,0,1,2 $$. Since both $$ \frac{dy}{dx} $$ and $$ D_{y} \frac{dy}{dx} $$ are continuous on the square region R defined by $$ -4\leq x \leq 4, -4 \leq y \leq 4 $$ the existence and uniqueness theorem guarantees that if we pick a point in the interior that lies on an isocline there will be a unique differentiable function (solution) passing through that point. I understand that a solution exists but I unsure how to actually sketch it. For example, consider a...
