Solving a Non-Linear Differential Equation Using Exact Equations
  • Context: Graduate
  • Thread starter Thread starter Tom1
    Method
The discussion revolves around solving a non-linear differential equation of the form dy/dt = -y^2 + y + 2t^2y + 2t - t^2 - t^4. Participants are exploring whether specific functions, y1(t) = t^2 and y2(t) = t^2 + 1, are solutions to this equation, as well as discussing methods for solving the equation itself.
  • One participant expresses difficulty in applying the method of exact equations to the given non-linear, non-separable differential equation.
  • Another participant suggests verifying if y1(t) and y2(t) are solutions by substituting them into the differential equation after finding their derivatives.
  • A later reply confirms the intention to show that y1(t) and y2(t) are solutions, indicating that solving the differential equation would imply these are particular solutions.
  • One participant demonstrates that y1(t) = t^2 satisfies the differential equation by substituting it and simplifying the equation to verify equality.
  • Another participant identifies the equation as a Riccati type and proposes a transformation method to find a general solution, contingent on knowing a particular solution.
Participants generally agree on the goal of showing that y1(t) and y2(t) are solutions to the differential equation. However, there are differing approaches to solving the equation and uncertainty about the methods to apply.
The discussion includes various assumptions about the applicability of methods like exact equations and transformations, which may depend on the specific forms of the functions involved. The steps to fully resolve the differential equation remain unresolved.
This discussion may be useful for those interested in non-linear differential equations, particularly in the context of Riccati equations and solution verification methods.
Tom1
Hi,
I am trying to:
Show that y1(t)=t^2 and y2(t)=t^2+1
for the differential equation:
dy/dt=-y^2+y+2t^2y+2t-t^2-t^4
This is clearly a non-linear, non-seperable equation, and I cannot see how to try the method of exact equations on it. Therefore, I am stuck.
Anyone have any ideas of what to try?
are you trying to show that y1(t)=t^2 and y2(t)=t^2+1
are two solutions of that diffl. eq or, just to solve that diff. eq? if the former is the case, all you need to do is find the derivative of y1, y2 and plug in the diff eq and see if the right hand is equal to the left hand. if the latter than ther is more work to do!
Trying to show that those are solutions to the diff. eq.
If I could solve the diff. eq. I guess it would show that those are particular solutions though.
y1'=2t, so
2t=-(t^2)^2+t^2+2t^2*t^2+2t-t^2-t^4=-t^4+2t^4 +2t-t^4=2t, so this is a solution. try the same thing with y2
Thank you much.
This equation is a Riccati type equation, i.e. [itex]y'(t)=a(t)\,y(t)^2+b(t)\,y(t)+c(t)[/itex]. The general solution can be found if one knows a particular solution [itex]y_p(t)[/itex] by the transformation [itex]y(t)=y_p(t)+\frac{1}{u(t)}[/itex] which makes it a linear one.
For the problem at hand if you write [itex]y(t)=t^2+\frac{1}{u(t)}[/itex] then the original ODE reduces to [itex]u'(t)=1-u(t)\Rightarrow u(t)=C\,e^{-t}+1[/itex].
