Simple Integral Solution: Finding the Value of a in ∫1/(x^2+a)dx Formula
  • Thread starter Thread starter Mr Davis 97
    Integral
The integral ∫1/(x²+a)dx can be expressed as ∫1/(x²+(±√a)²)dx, leading to the solution involving arctangent. The choice between the positive or negative root does not affect the final result due to the odd nature of the arctangent function. Both forms yield the same expression, specifically (1/√a) arctan(x/√a) + C. This confirms that the sign of the square root does not impact the integral's outcome. Understanding the properties of the arctangent function simplifies the solution process.
Mr Davis 97
##\displaystyle \int \frac{1}{x^2+a} dx##
I know that I can convert this to the form ##\displaystyle \int \frac{1}{x^2+(\pm \sqrt{a})^2} dx## = ##\displaystyle \frac{1}{\pm \sqrt{a}} \arctan (\frac{x}{\pm \sqrt{a}}) + C##, but I don't know whether to take the positive or the negative root.
Ask yourself whether it matters or not.
Likes member 587159
Does it not matter since ##\arctan## is an odd function, so in either case you get ##\displaystyle \frac{1}{\sqrt{a}} \arctan (\frac{x}{\sqrt{a}}) + C##?
Indeed.
Likes Mr Davis 97
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 105 ·
  • · Replies 22 ·
