Solving Abel Equation: Step-by-Step Guide
  • Context: Graduate
  • Thread starter Thread starter saltydog
The discussion revolves around the Abel equation and its solution process, focusing on the derivation steps, integral transformations, and mathematical reasoning involved. Participants explore various aspects of calculus related to integral equations, with an emphasis on understanding the underlying principles rather than specific applications.
  • One participant introduces the Abel equation and expresses a desire to derive its solution step-by-step, inviting comments and insights from others.
  • The first step involves defining an integral operator and applying it to both sides of the equation, leading to a transformation of the integral.
  • Another participant discusses switching the order of integration and describes the area of integration, resulting in a new form of the integral equation.
  • A change of variable is proposed to simplify the integral on the right-hand side, which leads to a cancellation that makes the equation easier to handle.
  • A participant corrects a previous statement regarding the terminology used, clarifying that the initial step should not be referred to as an "integral transform."
  • Further steps involve completing the square and deriving an expression for \(\phi(\xi)\) through differentiation, noting the challenges posed by discontinuities in the integrand.
  • One participant expresses enthusiasm for experimenting with various functions in Mathematica to explore the integral equation's behavior from a mathematical perspective.
Participants present various viewpoints and approaches to the problem, with no consensus reached on the best methods or interpretations. The discussion remains open-ended, with differing opinions on terminology and the steps involved in the solution process.
Participants acknowledge limitations in their understanding of integral equations and the potential for confusion in terminology. The discussion reflects a range of mathematical techniques and assumptions that may not be universally applicable.
saltydog
Homework Helper
I wish to study the Abel equation and think it's solution involves several aspects of Calculus that others here may find interesting. I'll post the derivation of the solution in steps; that helps me learn it and I hope will provide incentive to others to comment about the process. I'm not really good with integral equations and welcome any comments; my understanding is quite lacking. I just like them and see the potential of them (and IDEs) being used in artificial intelligence.
Here's the equation:
f(x)=\int_0^x{\frac{\phi(y)}{\sqrt{x-y}}}
With f(x) given and \phi(x) to be determined.
The first step in solving the equation is to define an integral operator, that is, an operator which takes a function and processes it with an integral. For this problem, Abel used the following integral operator:
I[f(x)]=\int_0^\xi{\frac{f(x)dx}{\sqrt{\xi-x}}}
Thus, applying this operator to both sides of the equation yields:
\int_0^\xi{\frac{f(x)dx}{\sqrt{\xi-x}}}=\int_0^\xi{\frac{dx}{\sqrt{\xi-x}}}\int_0^x{\frac{\phi(y)}{\sqrt{x-y}}}dy
The order of integration on the RHS needs to be changed next.
Switching the order of integration
It's easy for me to switch the order of integration when I consider the integral in the following form:
\int_0^\xi\int_0^x f(x,y;\xi)dydx
The area of integration is then the triangular region under the graph y=x in the range [0,\xi]. In this case, the integral becomes:
\int_0^\xi\int_y^\xi f(x,y;\xi)dxdy
And thus:
\int_0^\xi{\frac{dx}{\sqrt{\xi-x}}}\int_0^x{\frac{\phi(y)}{\sqrt{x-y}}}dy=\int_0^\xi\int_y^\xi \frac{1}{\sqrt{\xi-x}}\frac{\phi(y)}{\sqrt{x-y}}dxdy
The transformed integral equation becomes:
\int_0^\xi\frac{f(x)}{\sqrt{\xi-x}}dx=\int_0^\xi\phi(y)\int_y^\xi\frac{1}{\sqrt{\xi-x}\sqrt{x-y}}dxdy
The next step is to find a suitable change of variable that will facilitate evaluating the first iterated integral.
Using the change of variable x=y+(\xi-y)u, the integral on the RHS becomes:
\int_0^\xi \phi(y)\int_0^1\frac{(\xi-y)du}{\sqrt{(\xi-y-\xi u+yu)(\xi u-yu)}}}dy
Simplifying, we get:
\int_0^\xi \phi(y)\int_0^1\frac{du}{\sqrt{u(1-u)}}dy
Well, how convenient. This seems to be the critical part of the solution process. In this case, everything cancels. I'd like to come back to this part with a kernel that does not cancel so nicely but for now, I stick with the easy problem.
The equation is now:
\int_0^\xi \frac{f(x) dx}{\sqrt{\xi-x}}=\int_0^\xi \phi(y)\int_0^1\frac{du}{\sqrt{u(1-u)}}dy
The first iterated integral is easily solved.
Incorrect usage in first post
I now realize it's incorrect to call the first step in the solution process an "integral transform" as a transform would involve a "dummy" variable for the integral. Rather, I'm just multiplying both sides of the original integral equation by \frac{dx}{\sqrt{\xi-x}} and then integrating from 0 to \xi.
Continuing:
Completing the square in the radical, the antiderivative is in the form of ArcSin. The integral is equal to \pi
So that:
\int_0^\xi \frac{f(x)dx}{\sqrt{\xi-x}}=\pi \int_0^\xi \phi(y)dy
In order to isolate \phi, we differentiate both sides of the equation with respect to \xi so that:
\phi(\xi)=\frac{1}{\pi}\frac{d}{d\xi}\int_0^\xi\frac{f(x)dx}{\sqrt{\xi-x}}
The interesting point here is that Leibnitz's rule cannot be used here as the integrand is discontinuous at x=\xi. However, the integral can be simplified by parts leaving:
\phi(\xi)=\frac{1}{\pi}\frac{d}{d\xi}\{2f(0)\sqrt{x}+2\int_0^\xi \sqrt{\xi-x}f^{'}(x)dx\}
Or using Leibnitz rule:
\phi(\xi)=\frac{f(0)}{\pi \sqrt{\xi}}+\frac{1}{\pi}\int_0^\xi \frac{f^{'}(x)}{\sqrt{\xi-x}}dx
Wow, that's beautiful. Now it's time to begin experimenting with various functions f(x) in Mathematica in an effort to better understand the behavior of this integral equation from the perspective of "I don't care about the application, only the math".
For a numerical treatment (using FORTTRAN) visit wwwdotgeocitiessdotcomslashserienumerica
