Solving an Equation: Expert Tips and Tricks for Beginners
  • Thread starter Thread starter Gringo123
The discussion revolves around solving a rational equation involving fractions with different denominators, specifically the equation n/n+3 + 7/n+4 = 1. Participants are exploring methods to eliminate the denominators and simplify the equation.
  • Participants discuss the need to eliminate denominators and consider methods such as finding a common denominator. There are attempts to clarify the process of combining fractions and questions about the correct application of these methods to the given equation.
The discussion is active, with participants providing hints and suggestions for approaching the problem. Some participants are questioning their understanding of the methods, while others are trying to clarify the steps involved in finding a common denominator. There is no explicit consensus on the next steps, but guidance is being offered to help navigate the problem.
Participants are grappling with the differences between numerical examples and the variables in the equation. There is a focus on ensuring that the mathematical principles apply consistently regardless of whether numbers or variables are involved.
Gringo123
I'm not sure how to approach this type of equation. Can anyone help me out?
Solve the equation:
n/n+3 + 7/n+4 = 1
You want to get rid of the denominators first, then collect terms.
I'm still stuck I'm afraid. Getting rid of the denominators is easy is thety are the same but as these are different I need help with the method.
You can bring them under the same denominator by cross multiplying. Hint: what method would you use to add 1/3+1/4 together?
I would convert them both to a common demoninator, namely 12, so they would be easier to add: 4/12 + 3/12 = 7/12
Exactly, now apply the same procedure to the two fractions in your equation.
Does that mean that the next stage is to multiply the top and bottom of n/n+3 by 4, (giving 4n/n + 12) and the top and bottom of 7/n+4 by 3 (giving 21/n + 12)? We can then multiply both fractions by n + 12 leaving us with 4n + 21 = 1?
Am I on the right track?
No, we're not dealing with 1/3 and 1/4 in your equation. Post #5 was just an example. However you must use the same method. Perhaps it is instructive if you tell me exactly how you converted 1/3+ 1/4 into 7/12 (step by step). Then copy that method for denominators n+3 and n+4 instead of 3 and 4.
the LCM of 3 and 4 is 12, so 1/3 and 1/4 can both be expressed as twelfths, namely 4/12 and 3/12.
n+3 + n+4 = 2n + 7. Is that the common denominator I should be using?
maybe 7 + n / 2n + 7?
Where does n+3+n+4 come from? You don't claim that the common denominator for 1/4+1/3 is 3+4 so why would it be for the exercise at hand. The objective is to find a common denominator so you can add the two fractions together. For numbers you're doing it correctly, however n is just a number therefore n+3 is just a number and n+4 is just a number. The rules of mathematics don't suddenly change when you pick another number.
Perhaps an intermediate step. let's define a=n+3 and b=n+4. Can you add 1/a+1/b together in terms of a and b?
Gringo, the least common MULTIPLE of two numbers is a PRODUCT.
Since "n + 3" and "n + 4" are relatively prime, we must multiply them together to get their LCM. This is analogous to LCM(3,4) = 12 (NOT SEVEN!)
If you multiply the entire equation by the LCM/LCD, there will be no more fractions.
(But there will be a quadratic equation to solve...)
  • · Replies 17 ·
  • · Replies 32 ·
  • · Replies 25 ·
