Solving an immediate indefinite integral of a composite function
19 replies · 3K views
greg_rack
$$\int (\frac{1}{cos^2x\cdot tan^3x})dx$$
none
That's my attempt:
$$\int (\frac{1}{cos^2x\cdot tan^3x})dx = \int (\frac{1}{cos^2x}\cdot tan^{-3}x) dx$$
Now, being ##\frac{1}{cos^2x}## the derivative of ##tanx##, the integral gets:
$$-\frac{1}{2tan^2x}+c$$
But there is something wrong... what?
  • Skeptical
greg_rack said:
Homework Statement:: $$\int (\frac{1}{cos^2x\cdot tan^3x})dx$$
Relevant Equations:: none
That's my attempt:
Convert the denominator into a fraction with only sine and cosine factors. IOW, convert the ##\tan^3## factor. The resulting expression becomes a reasonably simple problem that can be done by nothing more complicated than substitution.
Is the OP's answer wrong?
The correct answer is ##-\frac{1}{2sin^2x}+c##
I did it, and it took me to the correct answer.
But then I found out the method explained in the OP which looks legit to me, but takes me to a wrong answer, and so I wanted to understand why
PeroK said:
That's what you got, isn't it?
I got ##-\frac{1}{2tan^2x}+c## 🤔
PeroK said:
Same thing. Don't forget the constant of integration!
What do you mean? How could ##tan^2x=sin^2x##?
@greg_rack it's because$$-\frac{1}{2\sin^2{x}} + c_1 = -\frac{1}{2} \csc^2 x + c_1 = -\frac{1}{2} (1+ \cot^2{x}) + c_1 = - \frac{1}{2\tan^2{x}} + c_2$$
  • Love
Thanks a lot guys!
This is the same sort of situation you get with the integral ##\int \sin(x)\cos(x)dx##.
You can do this in at least three different ways, of which I'll show two.
1. Let ##u = \sin(x)##, so ##du = \cos(x)dx##. The resulting antiderivative is ##-\cos^2(x) + C##.
2. Let ##u = \cos(x)##, so ##du = -\sin(x)dx##. The resulting antiderivative is ##\sin^2(x) + C##
These results look different, but because ##\sin^2(x) + \cos^2(x) = 1##, ##\sin^2(x)## and ##-\cos^2(x)## differ only by a constant, 1.
The third way involves writing the integrand as ##\sin(2x)##.
greg_rack said:
Thanks a lot guys!
Everyone has to learn this lesson once! Usually it's:
$$\int \sin (2x) dx = -\frac 1 2 \cos(2x) + C$$ And
$$\int \sin (2x) dx = \int 2 \sin x \cos x dx = -\cos^2 x + C$$ Which are related by the trig identity $$\cos(2x) = 2\cos^2 x - 1$$
  • Love
another non-trig one that can sometimes catch people out$$\frac{1}{a} \ln{ax} + c_1 = \int \frac{\mathrm{d}x}{ax} = \frac{1}{a} \int \frac{\mathrm{d}x}{x} = \frac{1}{a} \ln{x} + c_2$$
Another "favorite": In the integral ##\int\frac{1}{\sqrt{1-x^2}}dx##, depending on whether you substitute ##x=\sin(u)## or ##x=\cos(u),## you will get either ##\arcsin(x)+c_1## or ##-\arccos(x)+c_2.##
