Solving an Initial Velocity Problem for a Basketball Player
2 replies · 7K views
rockersdash
1. Homework Statement
A basketball player is standing 9.5 m from the basket, which is at a height of 3.1m. she throws the ball from a initial height of 2m at an angle of 35 degrees above the horizontal. The ball goes through the basket. Determine intial velocity.
2. Homework Equations
Vx = Dx/t
v2^2 = v1^2 + 2ad
Dy = (V sine∅) - 0.5GT^2
3. The Attempt at a Solution
I took only half the parabola diagram and assumed v2 is 0 m/s
Vert
v1 = ?
v2 = 0 m/s
a = -9.8 m/s^2
max height = 1.1 m
I used the equation
v2^2 = v1^2 + 2ad
and got v1 as 4.64 m/s and from there on on I found initial velocity at an angle.
BUT the textbook gives a different answer (11m/s) as the initial velocity at an angle.
I can't figure out why I'm getting this wrong and my teacher sasys she will come back to me as she can't figure the mistake in mine... so help LOL
PS I assumed the max height of the parabola of the ball is 1.1 m otherwise I couldn't think of any other way.
Am I doing to this problem right? please post your work if any :)
Vx = Dx/t [this is good--what is Vx in terms of initial velocity, V?]
v2^2 = v1^2 + 2ad
Dy = (V sine∅) - 0.5GT^2 [this is also good--you are correctly using V0,y = V sine∅. By the way, I now understand what you were trying to say by "max height": you meant to say "difference in height": (y - y0), which would be Dy in the above equation.]
I took only half the parabola diagram and assumed v2 is 0 m/s [this is not good because you don't know how high the ball will go, nor at what point between the player and the basket this occurrs]
Vert
v1 = ?
v2 = 0 m/s
a = -9.8 m/s^2
max height = 1.1 m [again, this is not "max height" but the "difference in height"]
I used the equation
v2^2 = v1^2 + 2ad
BUT the textbook gives a different answer (11m/s) [which is correct]as the initial velocity at an angle.
PS I assumed the max height of the parabola of the ball is 1.1 m :rolleyes: otherwise I couldn't think of any other way.
Use:
Vx = Dx/t
You have 2 equations and two unknowns (V and T). Should I just tell you that Vx = V cos∅, or was that already clear in your mind?
