Solving an Integral Problem: Find Volume of Solid
  • Thread starter Thread starter Metal
    Integral
The discussion revolves around calculating the volume of a solid formed by rotating a specific region defined by the inequalities y ≥ x², y ≤ √x, and y ≤ 1/(8x) around the x-axis. The user initially attempted to find the area using integrals but was advised that the volume can be directly calculated using the formula π∫[a to b] f(x)² dx, where f(x) represents the function being rotated. Clarification was provided on why this formula works, explaining that it sums the areas of circular discs formed by the rotation, with the radius being f(x). The user expressed gratitude for the explanation and acknowledged their understanding of the concept. The conversation highlights the importance of visualizing the geometric interpretation of integrals in solving volume problems.
Metal
Hello, I'm new around here. I was having trouble with a problem, i thought i could look for help on the net. Anyway here's the problem:
Calculate the volume of a solid obtained by the rotation around Ox of all points (x,y) in RxR where y >= x*x, y <= square root of x and y <= 1/(8x).
What I did was:
1/(8x) = x*x so x = 1/2
1/(8x) = square root of x so x = 1/4
And then i found the integrals which are:
+ Integral of square root of x times dx between 0 and 1/4
- Integral of x * x times dx between 0 and 1/4
+ Integral of 1/(8x) times dx between 1/4 and 1/2
- Integral of x * x times dx between 1/4 and 1/2
So this gives me the area, but i have no idea on how to calculate the volume.
Hope someone can help.
Tks...
And I'm sorry about my english, this is my first time writing math in english.
You have found the correct points of intersection which divides your problem into to areas: from 0 to 1/4 and then from 1/4 to 1/2.
For a function f(x), the volume of the solid of revolution obtained by rotating f(x) about the x-axis between x=a and x=b is given by:
<br /> \pi \int\limits_a^b {f\left( x \right)^2 dx} <br />
So you don't need the area -> no need to find the integrals you listed.
Do you think you can take it from here? If not: ask for help :smile:
Ok, tks...
But why does this integral calculates this volume?
I mean... you took those integrals i made and multiplied each for its f(x) and for pi. Why does that make the volume?
Again sorry about any wrong english.
If you revolve f(x) about the x-axis, you create 'circles' at each x-value with center (x,0) and radius f(x), perpendicular to the x-axis of course. To obtain the volume, you need to add all the areas of the discs, with the area given by pi*r² with r the radius. Here, r is f(x) so you integrate pi*f(x)² over the interval. Is that clear enough?
Because, the formula rotates the 2D shape around the x axis. Imagine drawing a triangle form the orgin to some point x = b. Now imaging rotating that triangle around the x-axis. If you are having problems visualising this, draw it in a piece of paper, cut it out and rotate the triangle towards you. Now, if you follow the outline of this triangle, you have formed a 3D cone. The integral gives the volume enclosed by the cone.
Edit: Apologies for jumping in TD
No problem at all!
Oh I see... That was quite obvious actually... Tks.
You're welcome :smile:
  • · Replies 105 ·
