Solving an ODE: Methods and Confusion
  • Level: Undergrad
  • Thread starter Thread starter n00by
    Ode
8 replies · 3K views
n00by
The equation I'm trying to solve is
[itex]\frac{dy}{dx} = \frac{y^2 - 1}{x^2-1}[/itex], given y(2) = 2
The methods I'm somewhat familiar with are separation of variables, integrating factor, and exact. I tried this:
[itex](x^2 - 1)dy = (y^2-1)dx[/itex]
[itex](x^2 - 1)dy - (y^2-1)dx= 0[/itex]
So, now it's an exact equation, right?
I tried integrating each part:
[itex]\int (x^2 - 1)dy = (x^2-1)y+c1(x)[/itex]
[itex]\int (y^2 - 1)dx = (y^2-1)x+c1(y)[/itex]
But now I'm confused what I'm supposed to do! If I just let the constants of integration be zero, then I have:
[itex](x^2-1)y[/itex]
[itex](y^2-1)x[/itex]
But what do I do with those?
I'm really confused :(
Hello,
Try this:
[tex]dy/(y^2-1)=dx/(x^2-1)[/tex]
You can apply partial fractions
Hi, I don't see how I can apply partial fractions to [itex]\frac {dy}{y^2-1}[/itex] ?
[tex]1/(y^2-1)=1/[(y+1)(y-1)]=A/(y+1)+B/(y-1)[/tex]
You would then be required to solve for A and B.
Thanks for your help, I really appreciate it.
Here's what I tried:
[itex]\frac{1}{y^2-1} = \frac{1}{(y+1)(y-1)} = \frac {A}{(y+1)} + \frac{B}{(y-1)}[/itex]
[itex]1 = A(y-1) + B(y+1)[/itex]
[itex]y = 1: 1 = 0 + B(2) \iff B = \frac{1}{2}[/itex]
[itex]y = -1: 1 = A(-2) + 0 \iff A = -\frac{1}{2}[/itex]
[itex]\therefore \frac{1}{y^2-1} = \frac {-\frac{1}{2}}{(y+1)} + \frac{\frac{1}{2}}{(y-1)} → \int (\frac {-\frac{1}{2}}{(y+1)} + \frac{\frac{1}{2}}{(y-1)})dy = \int (\frac {-\frac{1}{2}}{(x+1)} + \frac{\frac{1}{2}}{(x-1)})dx[/itex]
[itex]-\frac{1}{2}ln|y+1| + \frac{1}{2}ln|y-1| = -\frac{1}{2}ln|x+1| + \frac{1}{2}ln|x-1| + C_1[/itex] , x > 1, y > 1
[itex]ln(y+1)^{-\frac{1}{2}} + ln(y-1)^{\frac{1}{2}} = ln(x+1)^{-\frac{1}{2}} + ln(x-1)^{\frac{1}{2}} + C_1[/itex], raise by e
[itex](y+1)^{-\frac{1}{2}} + (y-1)^{\frac{1}{2}} = (x+1)^{-\frac{1}{2}} + (x-1)^{\frac{1}{2}}+ C_2, C_2 = e^{C_1}[/itex]
But I don't see how I can solve for y. Any hints?
Most of the time, it is enough to give the final equation in implicit form. To find the constant, you plug in the initial conditions: ie, y(2) = 2 means that x=2 and y=2. If the initial conditions were y(5) = 3, then it would be y=3 and x=5.
A minor nitpick but there's an algebra mistake in the last part:
Hint: [itex]ln(A) + ln(B) = ln(AB)[/itex]
HallsofIvy said:
Are you required to solve for y?
I'm supposed to "solve" the differential equation. Does that not require solving for y?
doesn't y = x + c satisfy this ODE?
y(2) = 2
2 = 2 + c
c = 0
so checking y = x via differentiation:
dy/dx = 1
then substitution:
dy/dx = (y^2 -1) / (x^2 - 1) = (x^2 - 1) / (x^2 - 1) = 1
sorry if I'm a little off base or this doesn't help much, I'm just used to solving PDEs and when you get them to ODEs just using some ansatz math.
