Solving David's Puzzling Circular Pasture Question
  • Thread starter Thread starter Dabonez
    Circular
To determine the length of the rope needed for a cow tied to a circular pasture to graze exactly half of the area, the pasture's radius is denoted as R, giving it an area of πR². The cow's rope length is represented as C, with the condition that C must be greater than R but less than R√2 to ensure the grazing area is limited to half of the pasture. The intersection of the two circles formed by the pasture and the cow's grazing area creates two segments that must be analyzed. The points of intersection, labeled A and B, form a chord that divides both circles. This geometric relationship provides the necessary framework to solve the problem effectively.
Dabonez
My maths teacher recently gave me a weird question which really got my attention, but I have not managed to solve it so far. It can't exactly be described as homework, although it would give me a huge bonus if I managed to hand in the results.
There is a pasture in the shape of a circle. A cow is tied to a point on the circle. How long does the rope have to be, so the cow manages to pasture exactly 1/2 of the grassland?
I'm looking forward to everybody's opinions, and thanks in advance!
David
Mathematics news on Phys.org
To start, assume the pasture has radius R, then the area of the pasture is \pi R^2.
It may help to assume that the center of the pasture lies on the positive x-axis, and that edge of the pasture passes through the origin.
Now, assume that the cow's rope has radius C and is tied to the origin. This is the center of a second circle having area \pi C^2.
You are looking for the intersection of these two circles.
Note that you can assume C>R if it is to cover half of the pasture.
Also, you know that C < R\sqrt{2}, since having C = R\sqrt{2} would mean that circle C (the cow's circle) would intersect circle R (the pasture circle) at (R,R) and (R,-R). This intersection is obviously greater than 1/2 the area of circle R.
So now we have R < C < R\sqrt{2}.
Assume the intersecting points between the two circles are A (at the top) and B (at the bottom). Line segment AB is a chord of both circles, and thus we have 2 circle segments.
This should give you enough information to get you on the right track...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
