Solving Discrete Distribution: P(X = 0 & 1)
The discussion focuses on generating a random variable X that is equally likely to be 0 or 1 using a biased coin. The method involves flipping the coin twice and ensuring the results differ to proceed to determine X's value. The probabilities of obtaining heads and tails are equal when reaching the final step, leading to the conclusion that P(X = 0) equals P(X = 1). The participants clarify that continuously flipping the coin until the last two results differ would not yield the same probabilities due to the inherent bias in the coin. The original method is confirmed as the correct approach to achieve the desired outcome.
Somefantastik
I need help getting started on this.
Want to generate a random variable X, equally likely 0, 1, using biased coin (heads probability p).
1. Flip coin, result is labled 0_{1}
2. Flip coin, result is labeled 0_{2}
3. 0_{1} = 0_{2}=> return to step 1
4. 0_{2}= heads => X = 0, 0_{2} = tails => X = 1
Show X is equally likely to be 0 or 1.
A good place to start would be showing P{X = 0} = P{X = 1}. Can you show me how to find those two probabilities?
In order to get past step 3, you have to have had one head and one tail on the two flips. Since the probs of HT and TH are equal, step 4 will give you 2 equiprobable results.
Keeping in mind that this is a biased coin, can someone please show me how to explicitly find P{X = 0}? I understand that it is equal to 1/2 but I need to see how to get there.
Prob(HT)=Prob(TH)=p(1-p). Prob(get to step 4) is 2p(1-p), therefore prob(X=0)=prob(X=1)=p(1-p)/(2p(1-p))=1/2.
Is there a simpler way to do this where you continuously flip a coin until the last 2 results are different, that sets X = 0 if the final flip is a head, X = 1 if final flip is a tail?
No. A sequence of heads followed by one tail has a different probability than a sequence of tails followed by one head. You always need to start fresh as described in your original statement.
