Solving Dynamics Problem: Tension & Friction w/ 3 Blocks
  • Thread starter Thread starter aiglosicicle
    Dynamics
The discussion revolves around a dynamics problem involving three blocks connected by a string over a frictionless pulley. The problem requires determining the tension in the strings and the coefficient of kinetic friction, given the acceleration of one block and the rough surfaces involved.
  • Exploratory, Conceptual clarification, Problem interpretation
  • Participants suggest equating forces in different directions and labeling known quantities on the diagram. Questions arise regarding the forces acting on the blocks, including gravity and friction.
Some participants have provided guidance on identifying forces and organizing the problem, while others express a need for more detailed assistance. Multiple interpretations of the problem setup are being explored.
The original poster mentions a deadline for the assignment, indicating a time constraint that may affect the depth of understanding and exploration of the problem.
aiglosicicle
Hello, I'm a high school physics student and i have trouble solving this dynamics problem related to tension and stuff... here's the question
3 blocks of masses 10kg, 5kg and 3kg are connected by a light string that pass over a frictionless pulley as shown. the acceleration of the 5kg block is 2ms^-2 to the left, and the surfaces are rough. find (a) the tension in each string and (b) the coefficient of the kinetic friction between the blocks and the surfaces.
The diagram is attached to my post. I drew a rough one in paint.
Please help me guys! I've got to hand in this assignment tomorrow and i can't do this question =(.
Equate the forces in the horizontal and vertical directions...
Think which force is acting in which direction, eg. the weight on the left only has a vertical component downwards...
Start out by labelling what you do know from the problem statement onto the diagram. You know the force of gravity on the outer two blocks, and you know the initial velocities of the blocks, right? What are the frictional forces on the two righthand blocks? Gravity, friction and string tension are the only forces acting on the blocks, right?
Thanks for the explanations but i still don't quite get it... Could i ask for more detailed help?
Just remember, you need three things. First is an understanding of Newton's laws, which help in organizing the math needed to solve the problem. Second, be ery clear with your labeling of your variables and yor axes. You can call them whatever you want and give anydirection the positive or negative choice, but once you choose, BE CONSISTENT WITH IT or your answer might turn out to be something different. And finally, take care with your trig, fractions, algebra and all that jazz.
  • · Replies 47 ·
  • · Replies 45 ·
