Solving Equation: ln(y)(x^4 - y^4) + ln(x)(y^4 - x^4) + (y^2 - x^2)^2 = 0
  • Context: Graduate
  • Thread starter Thread starter CIMP
The discussion revolves around solving the equation ln(y)(x^4 - y^4) + ln(x)(y^4 - x^4) + (y^2 - x^2)^2 = 0, specifically focusing on finding the value of "X" when "Y=5". The scope includes numerical methods, root-finding algorithms, and graphical analysis.
  • Homework-related
  • One participant seeks assistance in solving the equation for a specific value of Y.
  • Another participant questions what is meant by "solving" the equation and asks for clarification on the goal.
  • Some participants suggest that finding a numeric approximation is necessary, as explicit solutions using elementary functions may not be possible.
  • Trivial solutions such as y=x are noted, but the presence of logarithms requires x and y to be positive.
  • One participant mentions that plotting the function reveals behavior tending to -infinity for X<5 and +infinity for X>5.
  • Another participant corrects a misunderstanding regarding the domain of the original function, emphasizing that x and y must be positive.
  • There is a disagreement about whether x=5 is the only solution for y=5, with some arguing that it is a double root.
  • Participants discuss the implications of transformations on the original function's domain.
Participants express differing views on whether x=5 is the only solution corresponding to y=5, indicating a lack of consensus on this point. Some agree that numeric methods are necessary, while others assert that there are trivial solutions.
Limitations include the need for numeric methods due to the complexity of the equation and the restrictions imposed by the logarithmic terms on the values of x and y.
CIMP
Hello All,
Could you please indicate me how to resolve this equation:
ln(y) (x^4 - y^4)+ ln(x) (y^4 - x^4) + (y^2 - x^2)^2 = 0
I am really struggling with it...
Thanks in advance,
C:)
What exactly do you mean by solving it? What do you need to do?
Mentallic,
Thanks a lot for your reply.
I mean, I want to know the value of "X" when "Y=5".
Thanks in advance,
CIMP said:
Mentallic,
Thanks in advance,
Hey CIMP and welcome to the forums.
Do you know about root finding algorithms?
CIMP said:
Mentallic,
Thanks in advance,
Then what you're looking for is to solve explicitly for x. However, you can't do that with the use of elementary functions (the usual - addition, multiplication, square roots, powers, trig, exponentials). You will need to find a numeric approximation to the answer.
There are trivial solutions however such as y=x and y=-x, but notice that with logarithms present in the equation, this means you need to restrict x and y to be more than zero, so only y=x, x>0 is a trivial solution.
So, if y=5 then x=5 as well, but that's not the only solution. The others can be found by numeric methods.
How about this, to get going:
x^4-y^4=-(y^4-x^4)
So you could write (ln(y)-ln(x))(x^4-y^4)+(y^2-x^2)^2=0
ln(y/x)(x^4-y^4)+(y^2-x^2)^2=0
ln(y/x)(x^4-y^4)=-(y^2-x^2)^2
ln(y/x)(x^2-y^2)(x^2+y^2)=-(y^2-x^2)^2
ln(y/x)(x^2+y^2)=(y^2-x^2)
ln(y/x)=(y^2-x^2)/R^2
Where R is the distance from the origin.
I don't know if this helps at all- it may give you a better idea of what the graph looks like though :rolleyes:
Hello Mentallic,
Thank you very much for your help. I really could advance more with your explanation. I made a plot as suggested by Jamma, and I could see that the function when X<5 it tend to -infinit and if X>5 it also tends to +infinit.
Hello Jama,
Thank you very much for your advice. It is vey useful to make a plot of the function before going to more sophisticated things!
Hello Chiro,
I use Maxima and Matlab and it was the first time that I was looking how to extract the root algoritms with them, but it was quite harder to use it... :bugeye:In fact, I pass all the day of yesterday dealing with that. Then I give up and I ploted the function and it was easy easier to see that it has just one solution when X=5. By lucky!
But I need to learn how to use the software...
Thanks everybody. I am so happy to be in this forum. Thansk again for your time and help...
CIMP
Not quite. Even though ln(y/x) is real for x,y<0, the original equation was of the form ln(y)-ln(x) in which case x,y<0 is NOT valid. You need to keep in mind that whatever transformations you do, you only consider the domain of the original function, not your manipulated function.
Actually, I'm going to have to disagree with you here. It looks to me as if x=5 IS the only solution corresponding to y=5.
Ahh yes they're in fact double roots. Thanks for spotting it!
[tex]\ln{y}(x^4-y^4)+\ln{x}(y^4-x^4)+(y^2-x^2)^2=0[/tex]
[tex](y^2-x^2)\left(\ln{\frac{1}{y}}(x^2+y^2)+\ln{x}(x^2+y^2)+y^2-x^2\right)=0[/tex]
The first factor corresponds to the roots of [itex]y=\pm x[/itex] thus only [itex]y=x, x>0[/itex] to satisfy the domain, and the second factor is
[tex]\ln{\frac{x}{y}}(x^2+y^2)=x^2-y^2[/tex]
Which gives us the same roots as the other factor, since ln(1)=0.
Yes! :smile:
Thanks!
"Mathematics is the language of nature..."
thanks, i hat the same question
So we've just solved all your homework for you guys, pfft.
CIMP, in the future, please post your questions in the homework help section.
  • · Replies 16 ·
