Solving for Angular Frequency w: Help!
The discussion focuses on solving for angular frequency (w) in a parallel circuit consisting of a 10k ohm resistor and a 100uF capacitor, where the input impedance's absolute value is 2k ohms. The original approach led to a complex fourth power equation, which participants suggested was overly complicated. They emphasized the importance of correctly calculating the magnitude of impedance rather than just the real part. A more effective method was proposed, involving converting the impedance into polar form and using the quadratic formula to find w. Ultimately, the correct formula for w was derived, highlighting the relationship between resistance, capacitance, and impedance magnitude.
chopficaro
help me out guys i have a test on Wednesday, and I am stuck on a problem, it seems I am supposed to solve for angular frequency w but I am getting a 4th power equation for it which is unsolvable
a 10k ohm resistor and a 100uF capacitor are in parallel, determine the angular frequency w where the absolute value of the input impedance is 2k ohms
z=1/(1/10000+1/(jwc))
z=1/(1/10000+1/(jw(.0001))
z=(1/10000-1/(jw(.0001))/((1/10000+1/(jw(.0001))(1/10000-1/(jw(.0001)))
ok so I've conjugated the denominator of z so that the real part and the imaginary part are separated, we have a quadratic equation for w in the denominator
the absolute value of z is the sum of the squares of the real part and the imaginary part
|z|=2000=sqrt((1/10000)/((1/10000+1/(jw(.0001))(1/10000-1/(jw(.0001)))^2+(-1/(jw(.0001))/((1/10000+1/(jw(.0001))(1/10000-1/(jw(.0001)))^2)
now we have a 4th power equation for w in the denominator which is unsolvable, there must be something I am doing wrong
hi chopficaro! :smile:
(have a mu: µ and a couple of omegas: ω Ω :wink:)
z=(1/10000-1/(jw(.0001))/((1/10000+1/(jw(.0001))(1/10000-1/(jw(.0001))) …
why are you making it so complicated? :redface:
you know that |Z| = 2000, so |1/Z| = 0.0005,
and 1/Z = 1/104 + 1/1/jω10-4 = 10-4(1 + jω) …
carry on from there :smile:
i think what u are doing gives the real part of z, not the absolute value, which is the magnitude sqrt(real^2 +imaginary^2)
i don't think ur method takes into account the coefficient of j
(try using the X2 icon just above the Reply box :wink:)
chopficaro said:
i think what u are doing gives the real part of z, not the absolute value …
no, it should give you the whole of Z …
then you get the magnitude from that :wink:
if we vary the imaginary part, your solution for |z| doesn't change, its as though were setting z to a scalar resistance, its the real part not the magnitude, the magnitude is the absolute vale, that's what we are looking for
ok i got it
we NEED to cojugate the denominator if he gives us the real or immaginary part of z
if he gives us the magnitude |z| or the angle, we want to put the two in parallel by the rule of Zeq=Z1*Z2/(Z1+Z2)
so for a capacitor and a resistor in parallel we get
Z1=R
Z2=1/jwc
Zeq=R1(1/jwc)/(R1+(1/jwc))
Zeq=R1/(jwc(R1+1/jwc))
Zeq=R1/(R1jwc+1)
then INSTEAD OF CONJUGATING we put the numerator and denominator in polar form
remember to take j out of the imaginary part when converting to polar
Zeq=(R1<90)/denominator
denominator=(R1jwc+1) to polar = sqrt((R1wc)^2+1^2)<arctan(R1wc/1)
and if we cary out the division we get out impedance in polar form, and the magnitude is |z|
|Zeq|<angle=(R1/sqrt((R1wc)^2+1^2))<90-arctan(R1wc/1)
the problem is what is w given |Zeq| so we plug in a value for |Zeq| and we may have to use the quadratic formula to find w, but maybe not
|Zeq|=(R1/sqrt((R1wc)^2+1^2))
R1/|Zeq|=sqrt((R1wc)^2+1^2)
(R1/|Zeq|)^2=(R1wc)^2+1^2
(R1/|Zeq|)^2-1=(R1wc)^2
remember here that the sqrt can be + or -
+-sqrt((R1/|Zeq|)^2-1)=(R1wc)
+-sqrt((R1/|Zeq|)^2-1)/(R1C)=w !
10K
