Solving for Inverse of a Complex Matrix with Cayley-Hamilton Theorem
  • Thread starter Thread starter Delta what
The discussion revolves around finding the inverse of a complex matrix using the Cayley-Hamilton theorem. The original poster presents a matrix and its characteristic polynomial, expressing difficulty in obtaining the inverse, particularly due to their background with real matrices.
  • Exploratory, Assumption checking
  • Participants discuss the characteristic polynomial and eigenvalues, noting that one eigenvalue is zero, which implies the matrix is not invertible. There are questions about the implications of having a zero eigenvalue and its effect on the matrix's properties.
Participants have provided insights regarding the relationship between eigenvalues and the invertibility of the matrix. The discussion reflects a mix of attempts to clarify the original poster's confusion and the exploration of related concepts without reaching a definitive conclusion.
There is mention of the original poster's unfamiliarity with complex matrices and a request for guidance on mathematical notation within the forum. The discussion also touches on the implications of the Cayley-Hamilton theorem in relation to the matrix's characteristics.
Delta what
I have matrix F=(11,1, -i1,2, i2,1, 12,2)
I calculated the characteristic polynomial to be x2-2x
The question is to find the inverse of F
I am having a hard time trying to get the inverse out of this. I am used to dealing with real matrices so this may be the source of my error. I have done these with the usual case being that there was a constant term in the polynomial which one could get on the other side of the equality and get the inverse easily.
I am ending up with something like X2=2x and then multiplying by x-1 and ending up with x=2. What am I missing here?
Side note (new guy question) could someone point me into the direction of an explanation of how to do math notation of this forum such as matrices and similar?
If the characteristic polynomial is ##c(x)= x^2 - 2x## the eigenvalues are ##\lambda_1 = 0## and ##\lambda_2 = 2##. Since one of the eigenvalues is zero the matrix does not have an inverse.
Thank you for the help!
Also on the side note I found that LaTeX is used to write in various notations.
Here's a LaTeX FAQ: https://www.physicsforums.com/help/latexhelp/
The Cayley-Hamilton theorem tells you ##F^2 = 2F##. When you multiplied by ##F^{-1}##, you assumed the inverse exists, and this assumption leads to the conclusion that ##F=2I##, which clearly contradicts what you started with. Therefore, you would conclude that the assumption was wrong. ##F^{-1}## doesn't exist.
Thank you for your help vela!
Ray Vickson said:
OK. An easy way to see it is to note that the product of the eigenvalues equals the determinant; see, eg.,
http://math.stackexchange.com/quest...-a-is-equal-to-the-product-of-its-eigenvalues
for a simple proof.
So, if 0 is an eigenvalue the determinant of the matrix equals 0 ==> not invertible.
Little bit of a different question but pertains to the same matrices. If i have a eigenvalue of zero can i still use that as a value in my diagonal matrix?
Yes.
More elementary, if I understand your notation, then if you multiply the second row by i, and then add that to the first row you see that the matrix is singular.
