Solving Friedmann Equation w/ Friedmann Eqn Hmwk Stmt
3 replies · 5K views · last reply
Logarythmic
By substituting in
[tex]\left( \frac{\dot{a}}{a_0} \right)^2 = H^2_0 \left(\Omega_0 \frac{a_0}{a} + 1 - \Omega_0 \right)[/tex]
show that the parametric open solution given by
[tex]a(\psi)=a_0 \frac{\Omega_0}{2(1-\Omega_0)}(\cosh{\psi} - 1)[/tex]
and
[tex]t(\psi)=\frac{1}{2H_0} \frac{\Omega_0}{(1 - \Omega_0)^{3/2}}(\sinh{\psi} - \psi)[/tex]
solve the Friedmann equation.2. The attempt at a solution
I get
[tex]\dot{a} = a_0 \frac{\Omega_0}{2(1 - \Omega_0)}(\dot{\psi}\sinh{\psi})[/tex]
and
[tex]\dot{\psi}=\frac{2H_0(1-\Omega_0)^{3/2}}{\Omega_0(\cosh{\psi}-1)}[/tex]
but I can't get to the first equality. Is this the correct approach?
You may find it easier to write [tex]\dot{a} = \frac{\frac{da}{d\psi}}{\frac{dt}{d\psi}}[/tex]. Dividing by [tex]a_0[/tex] and squaring should leave you with some expression involving only [tex]\psi[/tex]. A little algebra is then all you need to re-express things in terms of [tex]a[/tex].
I get the right hand side to equal
[tex]H^2_0 \frac{2(1-\Omega_0}{\cosh{\psi}-1}[/tex]
and the LHS
[tex]H^2_0 \frac{(1-\Omega_0)\sinh^2{\psi}}{(\cosh{\psi}-1)^2}[/tex]
but I can't get them equal...
I agree with your second expression from computing da/dt, but I think you've made a mistake with your first expression.
