MHB Solving how many square inches within a flag
  • Thread starter Thread starter wtam1100
    Square
The discussion focuses on calculating the area of a white stripe on a flag, identified as a parallelogram. To find the area, the formula A = base x height is used, with dimensions of 72 inches for the base and 8.5 inches for the height. Participants confirm that the area calculates to 612 square inches. A diagram is suggested as a helpful tool for understanding the problem. The conversation emphasizes the importance of identifying the correct measurements for accurate area calculation.
wtam1100
Hello all. I'm new here. Trying to help my daughter with her homework but I can't solve this problem wondering if there is any out there that is willing to help. Thanks a Head of time.
Mathematics news on Phys.org
Re: Solving how many square inches with in a flag
The white stripe is a parallelogram, whose area is found by computing the product of the base and the height. Can your daughter identify the measures of the base and height?
Yeah I think you are right. I'm just going with the 72 x 8.5. thanks for you input.
Yes, that's correct! (Star)
Hi,
I think a diagram is helpful:
the white area is essentially a parallelogram
to calculate the area of a parallelogram
A = base x height
A = 8.5 x 72 = 612 square inches
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
