Solving Improper Integrals with Integration by Parts
  • Thread starter UMich1344
    Integrals
UMich1344
Calculate [tex]\frac{1}{\sqrt{2\pi}}\int^{\infty}_{-\infty}x^{2}e^{-\frac{x^{2}}{2}}dx[/tex]
Use the fact that [tex]\int^{\infty}_{-\infty}e^{-\frac{x^{2}}{2}}dx=\sqrt{2\pi}[/tex]
I'm assuming that integration by parts is the best way to solve this.
http://www.math.hmc.edu/calculus/tutorials/int_by_parts/"
I want to use integration by parts in order to solve this. I've attempted both combinations of u and v'. However, I'm not able to get an integral in any of my solutions that looks like the one above that is set equal to [tex]\sqrt{2\pi}[/tex].
I have plugged the equation into Mathematica and the answer comes out to be 1. However, getting my work to back that up is proving to be difficult.
Is integration by parts the right way to go about solving this one? Any help is greatly appreciated.
The integrand is the density of the standard normal distribution, which is why Mathematica gave you the answer it did.
You should try integration by parts; with a judicious choice of [tex]dv[/tex] you will find that the
[tex] \int \, dv[/tex]
portion (to calculate [tex]v[/tex]) is easily done. After the step, and you have
[tex] \int u \dv = uv - \int v \, du[/tex]
you will see the reason for the hint.
Yes, we know what integration by parts is! How about showing exactly what you did so we can point out any mistakes?
I have attached my work with this post. I felt that I was heading in the right direction, but obviously I must have done something wrong near the beginning I would assume, since by the end I found that my integral diverged.
  • Handwritten-style worked derivation of the second moment m2 as an improper integral of x squared times e to the minus x squared over two, using integration by parts with limits as a goes to minus infinity and b goes to infinity, ending in terms with sqrt(2 pi) b squared and a squared.
