Solving Integral Equation: sin(x)+∫_0^π sin(x-t)y(t)dt
The discussion revolves around solving the integral equation y(x) = sin(x) + ∫_0^π sin(x-t)y(t)dt, which falls under the subject area of integral equations and differential equations. Participants explore various methods to approach the problem, including differentiation and integration by parts.
  • Mixed
  • Participants discuss differentiating the equation to simplify it and explore the implications of doing so. There are attempts to apply integration by parts, with some questioning the validity of this approach. Others suggest using Laplace transforms or considering the nature of the integral limits.
The discussion is active, with multiple participants contributing different methods and questioning each other's reasoning. Some participants have made progress in deriving expressions for y'(x) and y''(x), while others are still clarifying their understanding of the integration techniques and the implications of their calculations.
There are mentions of specific constraints, such as the limits of integration and the form of the integral equation, which influence the methods being considered. Participants also express uncertainty about how to derive initial conditions and evaluate integrals in the context of the problem.
sara_87
solve the following integral equation
y(x)=sin(x)+\int_0^\pi sin(x-t)y(t)dt
If the limits of integration were from 0 to x then i could solve this using Laplace transfroms because the definition of the convolution is:
integral g(x-t)y(t) where the limits are from 0 to x.
But here, we have the limits from 0 to pi.
Does anyone have any ideas.
Thank you
How about if you differentiate with respect to x twice. What happens if you add that to the original equation?
after I differentiate once, I get:
y'(x)=cos(x)(1+\int^\pi_0 (cos(t)-sin(t))y(t)dt)
differenitiating agin gives
y''(x)=-sin(x)(1+\int^\pi_0(cos(t)-sin(t))y(t)dt)
adding to the original gives
y''+y=\int^\pi_0 (sin(x)-cos(x))sin(t)y(t)dt
is that right?
What shall i do now?
let's try to solve this integral by integration by parts twice:
take,
\int_0^pi \sin(x-t)y(t)dt
let u=y(t) then du=y(t)dt
dv=sin(x-t)dt then v=cos(x-t)
apply u*v -\int vdu
we will obtain two factors A+\int cos(x-t)y(t)dt
another time integrate the second integral by parts we will obtain the same integral as above we will get 2*the first integral and solve for it!
the first integral i wrote above i mean pi and not from 0--->p, writing mistake!
I think you made a mistake,
if u=y(t) then u'=y'(t) because we are integrating with respect to t.
so in the intgrand we will have y'(t) and if we integrate by parts again, we will have y''(t) in the integrand.
yes you'r right i have made a mistake.
take u=y(t) du=y'(t)dt
dv=sin(x-t)dt v=-cos(x-t)
then after calculating it, calculate the second integral by the same method but take
u=cos(x-t) du=sin(x-t)dt
dv=y'(t)dt v=y(t)
I don't think this is the right approach. after the integration by parts, we get that the integral =0 leaving us with
y(x) = sin(x)
is this right?
is that right?
I get that y''(x)=(-sin(x))+integral(-sin(x-t)*y(t)). So y(x)+y''(x)=0. I don't see how you are factoring a cos(x) out of that first derivative.
How did you pull the cos(x) out of the integral? You just want to differentiate sin(x-t) wrt x and leave it all inside the integral, i.e.
\int sin(x-t)y(t)dt \Rightarrow \int cos(x-t)y(t)dt
thank you both for pointing out my mistake.
after differentiating twice and adding y and y'' I get
y''(x)+y(x)=0
so the solution is
y(x)=Acos(x)+Bsin(x)
to find A and B I need initial conditions.
How can I get the initial conditions?
y''(x)+y(x)=0
so the solution is
Plug your y(x) into the integral equation. Now you can explicitly do the integral. If you move all of the terms to one side you will get something like c*sin(x)+d*cos(x)=0 (where c and d are linear functions of A and B). Now what?
thanks,
i did this just now and got that:
c=A-1-pi*B/2
d=B+pi*A/2
A=4/(4+pi^2)
and
B=-2Pi/(4+pi^2)
is this right?
Right. You set c=d=0. Those look like the same values I got for A and B.
wohoo, thanks.
Im doing another question and it is the same as this one but instead of sin(x-t)y(t) in the integrand, i have (x-t)y(t) in the integrand.
Do I also differentiate twice?
sara_87 said:
wohoo, thanks.
It's certainly worth a try. What do you think will happen?
Why integration by parts is wrong in such a case?
we have
y(x)=1+\int_0^1 (x-t)y(t)dt
y'(x) = \int_0^1 y(t)dt
y''=0
hmmm...do i add them? :confused:
sara_87 said:
we have
y''=0
Well, you don't need to. y''=0 is already an ODE you can easily solve.
For one thing, you did it wrong. If u=y then du=y'(x)dx. Now there's a y'(x) in your integral. The next time you integrate by parts you get y''(x). You aren't going to get back where you started. You are just making things more complicated.
when I solve y''=0 and then substitute it into the original equation I get:
x(A*1/2+B)+(A*1/3+B*3/2-1)=0
how will this help to find A and B?
The same as the other one. If c*x+d=0 for all x, then c=0 and d=0.
wohoo, thank you very much.
I get A=-12/5 and B=6/5
just one final question,
If now instead of (x-t)y(t) in the integrand, I have ln(x/t)y(t), do i still use differentiation?
I would then get:
y'(x)=\frac{1}{x}\int_0^1 y(t)dt
y''(x)=\frac{-1}{x^2}\int_0^1 y(t)dt
Step back and think about it. The whole game here is to eliminate the integral so you just have an ODE in y(x) left. Can you think of a way to use those two equations to eliminate the integral? I'll bet you can.
ya, I can :biggrin:
I get:
y'' + 1/x y'=0
solving gives:
y(x) = Aln(x)+B
is this right?
then i do the same as before to find A and B, right?
sara_87 said:
ya, I can :biggrin:
I get:
y'' + 1/x y'=0
solving gives:
y(x) = Aln(x)+B
is this right?
I think you've got it.
woohooo
Thanks ;)
I'm just wondering how did get these combinations for the constants after you've plugged your solution into the integration equation.
You calculate the integral.
i know you calculate the integral to obtain the constants, but I am just at a loss in doing what you both did.
the solution to the ODE would be y = Ax + B. when inserted into the original equation,
Ax + B = 1 + (int 0->1) (x-t)y(t)dt
(A - (int 0->1)y(t)dt)x + (B - 1 + (int 0->1) ty(t)dt) = 0
I'm just wondering how you evaluated those integral terms into the constant terms.
I had a similar query about the question done before as well.
