Solving integral - gaussian distribution of cos
The discussion centers on proving an integral involving a cosine function and a Gaussian distribution. The integral can be simplified by changing the limits from negative to positive infinity, given that sigma is much smaller than L_av. Participants suggest looking up known integral solutions and consider using complex exponentials to simplify the cosine term. Clarifications are requested regarding the notation used for L_av and the structure of the expressions to avoid confusion. The goal remains to establish the proportional relationship between the integral and the specified cosine and exponential terms.
poul
I have to prove:
∫(-infinity:infinity) cos(pi*v/2L)*e^-((L-L_av)^2/sqrt(2pi)*sigma^2) dL proportional to
cos(pi*v/2L_av)*e^-(t/tau)^2
tau is some constant, and sigma << L_av.
i can change the integral to 0:infinity, since sigma << L_av. Then i have to look up some integral solution, probably:
∫(0:infinity) cos(bx)*e^-ax^2 dx
I assume i have to do some trick like 1/L approximately L/L_av^2 - but how can i justify that?
Can you use complex numbers? If so, you can rewrite your cosine in term of complex exponentials which will make things quite easy.
poul said:
I have to prove:
It is very unclear what your original problem is, because you do not use brackets. You have something written as L_av. Does this mean Lav or does it mean Lav? If you mean the first, write L_{av} or L_(av), and if you mean the second, either write a*L_v or (L_v)a. Better still, use the "X2" button in the menu above the input panel. Anyway, setting L_av = c, some constant, it is still not clear whether you mean
\cos \left( \frac{\pi v}{2L} \right) \text{ or } \cos \left( \frac{\pi v}{2} L \right) in the integrand. If you mean the first, write cos(pi*v/(2L)), but if you mean the latter, write cos((pi*v/2)L).
Similarly, when you write e^-ax^2, you are literally writing ##e^{-a} x^2## if we read it using standard rules and conventions. I guess you mean ##e^{-ax^2},## which is e^{-ax^2} or e^(-ax^2) in plain text, or better still, e-ax^2 or e-ax2, using the "X2" button in the menu at the top of the input panel.
RGV
Okay, I have to prove:
∫(-infinity:infinity) cos(pi*v/(2L))*e-((L-L_{av})^2/(2*sigma^2)) dL proportional to
cos(pi*v/(2L_{av}))*e-(t/tau)^2
sigma << L_{av} - both positive
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
