Solving Integral in Picture: Step-by-Step Guide
  • Context:
  • Thread starter Thread starter FilipVz
    Integral Picture
7 replies · 3K views
FilipVz
Can somebody explain how to solve integral from the picture above?( solution is in the second line)
I haven't worked out the solution yet, but given the answer and the general form of the integral I would guess trig substitution is the way to solve it. Question though - should the $(1-k^2)$ in the denominator actually be $(1-k^2)^2$?
If that's not the way to solve it then maybe there's something with the substitution $(k \cot(\theta))^2=k^2 \cot^2(\theta)=k^2(\csc^2(\theta)-1)$, but I'm not sure yet. Will post back if anything comes to mind.
Hint :
$$\frac{d}{dx} \left(\cos^{-1} (f) \right) = \frac{-f'}{\sqrt{1-f^2}}$$​
Hint: Try the substitution:
$$\cot(\theta)=\frac{\sqrt{1-k^2}}{k}\cos(u)$$
Hence:
$$\csc^2(\theta)\,d\theta=\frac{\sqrt{1-k^2}}{k}\sin(u)\,du$$
And the result will follow. :D
Hence:
No need for substitution. Of course it is more advisable on an elementary level .
Thank you,
i solved it, using substitution:
$$u= (k*ctgθ)/(1-k^2 )$$
But, my result is:
$$ϕ=-arcsin((k∙ctgθ)/√(1-k^2 ))+c_2$$
instead of
$$ϕ=arccos((k∙ctgθ)/√(1-k^2 ))+c_2$$
Is this correct?
FilipVz said:
Thank you,
But, my result is:
instead of
Is this correct?
Yes, that's another possible form. Consider the identity:
$$\sin^{-1}(x)+\cos^{-1}(x)=\frac{\pi}{2}$$
along with the fact that the sum of an arbitrary constant and another constant is still an arbitrary constant. :D
$$\int \frac{-1}{\sqrt{1-x^2}} \, dx = \cos^{-1}(x)+A$$
$$-\int \frac{1}{\sqrt{1-x^2}} \, dx = -\sin^{-1}(x)+B$$
And this simply because
$$\cos^{-1}(x)+\sin^{-1}(x) =\frac{\pi}{2}$$
