Solving Integrals with Exponential Functions
  • Topic:
  • Thread starter Thread starter bergausstein
    Bernoulli
9 replies · 3K views
bergausstein
Solve the ff:
$\displaystyle\frac{dy}{dx}-y=xy^5$
$\displaystyle\frac{dy}{dx}-\frac{y}{x}=-\frac{5}{2}x^2y^3$
can you help start solving these problems? thanks!
These are Bernoulli equations. Such an equation may be written in the form:
$$\frac{dy}{dx}+P(x)y=Q(x)y^n$$
Use of the substitution:
$$v=y^{1-n}$$
will transform the ODE into a linear equation.
the n=5
$\displaystyle v=y^{1-5}=\frac{1}{y^4}$
$\displaystyle y=(\frac{1}{v})^{\frac{1}{4}}$
$\displaystyle y'=-\frac{1}{4}v^{-\frac{5}{4}}\frac{dv}{dx}$
substitute,
$\displaystyle y=(\frac{1}{v})^{\frac{1}{4}}$ and $\displaystyle y'=-\frac{1}{4}v^{-\frac{5}{4}}\frac{dv}{dx}$ to the original D.E
$\displaystyle -\frac{1}{4}v^{-\frac{5}{4}}\frac{dv}{dx}-\frac{1}{v^{\frac{1}{4}}}=x\frac{1}{v^{\frac{5}{4}}}$
multiplying both sides by $v^{\frac{5}{$}}$ and -4.
$\displaystyle \frac{dv}{dx}+4v=-4x$
the integrating factor is $e^{4x}$
$\displaystyle e^{4x}\frac{dv}{dx}+4ve^{4x}=-4xe^{4x}$
$\displaystyle \int D_x(e^{4x}v)=\int -4xe^{4x}$ the rhs using by parts
$\displaystyle e^{4x}v= -e^{4x}+\frac{1}{4}e^{4x}+c$
dividing both sides by $ e^{4x}$
$\displaystyle v= -1+\frac{1}{4}+\frac{c}{e^{4x}}$
now since $v=\frac{1}{y^4}$
$\displaystyle\frac{1}{y^4}=\frac{c}{e^{4x}}-\frac{3}{4}$ --->> this would be my implicit general solution
is my answer correct?
We are given:
$$\frac{dy}{dx}-y=xy^5$$
Use the substitution:
$$v=y^{-4}\implies\frac{dv}{dx}= -4y^{-5}\frac{dy}{dx}$$
Divide the original ODE by$y^5$ observing we are eliminating the trivial solution $y\equiv0$. We obtain:
$$y^{-5}\frac{dy}{dx}-y^{-4}=x$$
Applying the substitution we obtain:
$$\frac{dv}{dx}+4v=-4x$$
Multiply through by $e^{4x}$:
$$e^{4x}\frac{dv}{dx}+4e^{4x}v=-4xe^{4x}$$
This becomes:
$$\frac{d}{dx}\left(e^{4x}v \right)=-4xe^{4x}$$
Integrating (using IBP on the right (which you did incorrectly)), we obtain:
$$e^{4x}v=\frac{1}{4}e^{4x}\left(1-4x \right)+C$$
$$v=\frac{1}{4}\left(1-4x \right)+Ce^{-4x}$$
$$y^{-4}=\frac{1}{4}\left(1-4x \right)+Ce^{-4x}$$
Thus the solution may be given implicitly by:
$$y^4=\frac{4}{1-4x+Ce^{-4x}}$$
Note: the trivial solution we eliminated is not obtainable by the implicit solution gave above.
can you tell me where's my mistake in my solution above?
Edit: There is a small mistake in the integration. Sorry.
[tex]\displaystyle \begin{align*} \int{-4x\,e^{4x}\,dx} = -4x\,e^{4x} + \frac{1}{4}e^{4x} + C \end{align*}[/tex]
$\displaystyle e^{4x}v= -xe^{4x}+\frac{1}{4}e^{4x}+c$
$\displaystyle v= -x+\frac{1}{4}+\frac{c}{e^{4x}}$
my final answer should be$\displaystyle\frac{1}{y^4}=\frac{c}{e^{4x}}-x+\frac{1}{4}$
am I right?
am I right?
Please re-read my last post. You keep missing the factor of -4 on the first term.
$\displaystyle\int -4xe^{4x}dx=-4\int xe^{4x}$
let $u=x$ and $du=dx$
let $dv=e^{4x}dx$ now $v=\frac{1}{4}e^{4x}$
$uv-\int vdu$
$\frac{1}{4}xe^{4x}-\frac{1}{4}\int e^{4x}dx$
$-4\left(\frac{1}{4}xe^{4x}-\frac{1}{4}\frac{1}{4}e^{4x}+c\right)= -xe^{4x}+\frac{1}{4}e^{4x}+c$
isn't correct?
$uv-\int vdu$
isn't correct?
Never mind, what you have is correct. I forgot the 1/4 factor in the v term.
I think this many mistakes means it's time for bed >_<
