Solving Logarithms: Finding the Inverse of g(x)=3+x+e^x
  • Thread starter Thread starter kdinser
    Logarithms
To find the inverse of the function g(x) = 3 + x + e^x, the focus is on solving the equation 3 + x + e^x = 4, which simplifies to x + e^x = 1. The key insight is that g(0) equals 4, leading to the conclusion that g^-1(4) = 0. The discussion clarifies that the problem does not require finding the general inverse function g^-1(x), but rather just evaluating it at x = 4. Ultimately, the solution confirms that g^-1(4) = 0 is correct.
kdinser
Greetings all, I'm doing a refresh of calculus and physics in preparation for getting back to school this fall after a 5 year layoff. Most stuff is coming back pretty quickly, but I'm stuck on this one problem. I'm sure I'm missing something small, but I just haven't been able to find any example problems that match this one.
g(x)=3+x+e^x
g(x)=y
I need to find the inverse of this function, which means solving for x. If I take the ln e^x to get x, I'm stuck on the other side with ln (y-3-x)=x I'm not sure where to go from here, any help would be greatly appreciated.
Mathematics news on Phys.org
Since g has x both "inside" and "outside" the exponential, its inverse is not any "elementary" function. Exactly what does the problem ask you to do?
If your finding the root of the equation then you want to find x for:
3 + x + e^x = 0
And I must say I'm a little stumped on how you would work out an exact answer.
if g(x)=3+x+e^x Find g^-1(4)
I'm reading this as "find the inverse g(x) function and then solve it when x=4" The answer in the back of the book shows that it should be 0.
The inverse of g(x = 4) is 1/(7 + e4) though.
that isn't the inverse, that's the reciprocal.
by inspection g(0) = 3+0+e^0 = 4,
(technical note, g is monotone increasing so inverse is well defined)
hence g^{-1}(4) = 0
and similiarly g^{-1}(4+e) = 1
Since it wasn't immediately apparent to me what matt was doing, here's a general point:
For some function f(x),
If:
f(b)=a
Then:
f^{-1} (a) = b
Yep. The problem did NOT ask that you actually find g-1(x),
only that you find g-1(4).
That is exactly the same as solving the equation 3+ x+ ex= 4 or
x+ ex= 1. There is still no general way of solving an equation like that, but you might be as smart as Matt Grime and recognize that if x= 0, e0= 1 so
0+ e0= 1. g-1(4)= 0.
Thanks guys, after thinking about Matt's answer, I'm pretty sure that's what the problem was getting at.
need help solving a problem can u help
If you will post your problem in a new thread I am sure a lot of people can help.
