Solving Particular Integral of Polynomial & Exponential
  • Thread starter Thread starter enosthapa
    Integral
The discussion focuses on solving the particular integral (PI) of the differential equation y'' + 5y' + 4y = x^2 + 2e^(-x). The auxiliary roots are identified as m1 = -1 and m2 = -4. Participants emphasize that when the right-hand side (RHS) contains an exponential term that is also a solution of the left-hand side (LHS), it cannot serve as a PI by itself. Instead, it must be multiplied by x, leading to the proposed solution form of xe^(-x) combined with a polynomial.
  • Understanding of differential equations and their solutions
  • Familiarity with auxiliary equations and roots
  • Knowledge of particular integrals in the context of non-homogeneous equations
  • Experience with exponential functions and their derivatives
  • Study the method of undetermined coefficients for solving non-homogeneous differential equations
  • Learn about the variation of parameters technique for finding particular integrals
  • Explore polynomial and exponential function combinations in differential equations
  • Review examples of solving differential equations with repeated roots in the auxiliary equation
Students and professionals in mathematics, particularly those studying differential equations, as well as educators seeking to clarify methods for solving particular integrals involving polynomial and exponential terms.
enosthapa
y''+5y'+4y=x^2+2e^(-x)
Auxiliary roots: m1=-1 m2=-4
Using trial please
cant seem to work out PI with polynomial and exponential together.
hi enosthapa! :smile:
(try using the X2 icon just above the Reply box :wink:)
when your RHS contains an exponential which is a solution of the LHS, it obviously can't be a PI on its own (as you've found out! :redface:) …
you need to multiply it by x (or xn is it's an nth root of the LHS) …
in this case, try xe-x (plus a polynomial) :wink:
Thanks a lot but I am still confused
As far as i know,
if there is exponential on RHS (ekx) and if 'k' is simple root of the auxiliary equation which it is in this case, then we try a.x.ek.x i.e a.x.e-x
but the question has polynomial in addition so did you mean i have to add the 'PI' I would get if there was polynomial only on RHS?
sorry i m confusing u:/
i meant a polynomial plus a constant times xe-x
doesn't that work? :confused:
I don't have the answer which could have been helpful. But thanks anyway.
Moderator's note: thread moved from "Differential Equations".
The usual rules rules for giving homework help are now in effect.
  • · Replies 19 ·
