Solving Pulley Systems with Multiple Masses and Angles
  • Thread starter Thread starter mburt
    Pulley Systems
The discussion focuses on solving a physics problem involving a crate being raised using a system of pulleys at a 45-degree angle. The masses involved are m1=3.5 kg, M2=6.5 kg, and MC=44.2 kg. The correct minimum tension required to slowly raise the crate is determined to be 248.7 N, after resolving the relationships between the tensions in the system. Key equations derived include T1 + T2 - M2g - MCg = 0 and the relationship T1 = T2 = T3 due to the continuous string.
  • Understanding of Newton's laws of motion
  • Familiarity with free body diagrams (FBDs)
  • Knowledge of tension in pulley systems
  • Basic trigonometry, specifically sine functions
  • Study the principles of tension in multi-pulley systems
  • Learn how to analyze free body diagrams for complex systems
  • Explore the effects of angles on tension and force distribution
  • Review problem-solving techniques for physics involving multiple masses
Students studying physics, particularly those focusing on mechanics and pulley systems, as well as educators seeking to understand common student challenges in solving tension-related problems.
mburt
A crate is pulled up using frictionless pulleys in the manner shown in the figure. The angle is 45 degrees. The masses are, for the small pulley, m1=3.5 kg, for the traveling pulley, M2=6.5 kg, and for the crate, MC=44.2 kg. What is the minimum tension with which the operator must pull on the cable (assume the cable is of negligible mass) in order to slowly raise the crate.
(See the attached picture below)
First of all note that in the diagram attached, the BLACK parts are the original question, and the RED parts are things I added to help in solving it.
1) I know that T3 has to support at least m1. How would I figure out how much of M2 and MC it supports?
2) Does the Y component of T (ie. Tsin45) equal T2 in the diagram?
3) Since the problem says "slowly raise", does this mean that net force in the Y-direction is zero?
Well I drew FBDs at m1, and M2 and ended up with these statements:
At m1:
T3 + Tsin45 - T2 - m1g = 0
At M2:
But seeings there's only 2 equations and 4 unknowns it seems unsolvable.
There must be SOME relationship between T, T1, T2, and T3 that I'm not seeing.
Thanks in advance,
Mike
In this situation, since all the tensions are from the same string, T1=T2=T3=T
Wow really? Are you sure it's that simple?
Its the same string without any node. any pull on the other side will affect the whole string right?
Ok that seems like it makes sense...one more question though.. how would the pulley with mass = m1 affect the system? Since it's attached to the ceiling wouldn't it's weight be canceled out by T3?
m1 won't take any account unless it has friction.
Alright thanks, I'll try to solve this again now. I appreciate your help
I got an answer of T = 351.7N but unfortunately that's not right.I came up with the statement:
T1 + T2 - M2 - MC = 0
Where T1 and T2 = Tsin45
So:
2Tsin45 = 497.367N
and T = 351.7N
But this isn't the right answer... Thanks again for your help!
Do you have the answer sheet? what's the correct answer?
I don't have the answer sheet, but its an online assignment and when I enter an answer It tells me if its wrong.
The only thing I can figure is that the tension on the left side of the larger pulley is different than the tension on the right side of that pulley
hmmm... did I miss something... >.<
try 248.7
Okay sorry for being not able to help. got a little confused
No don't say sorry, I appreciate your help!
I only have two tries left so I might try to work it out again...maybe i'll get some more understanding about this question
248.7N was the correct answer...so thanks!
I guess no matter what the angle T is at it will always be equal to the tension on the other side of the pulley
Oh haha!
The problem is I didn't know what's the purpose of the angle, so I got confused lol.
Thanks too that I learned something here :D
  • · Replies 34 ·
