Solving Space-Time Variation in the Ocean
vdv
Hi all,
I m not a physicist but a biological oceanographer. I would like to know how should I consider space-time variations of tiny cells in the ocean? Usually people deal with space and time separately but do not compute the data over a space-time scale (which I believe is important especially in regards to the continuous movement of the water in the ocean). Each data point of my data set correspond to a specific location sampled at a specific time, I have data for 6 locations (of a particular region) and 6 time-periods (months), and would like to know the evolution of my tiny cells over a space-time frame. What kind of formula should I apply? How would you approach this problem?
Many thanks!
Cell simulations are similar to iterative finite element methods. They are a branch of bioinformatics. There should be a lot of papers on this. And even some commercial software.
The simplest form is this:
http://en.wikipedia.org/wiki/Conway's_Game_of_Life
Thread 'Can this experiment break Lorentz symmetry?'
1. The Big Idea: According to Einstein’s relativity, all motion is relative. You can’t tell if you’re moving at a constant velocity without looking outside. But what if there is a universal “rest frame” (like the old idea of the “ether”)? This experiment tries to find out by looking for tiny, directional differences in how objects move inside a sealed box. 2. How It Works: The Two-Stage Process Imagine a perfectly isolated spacecraft (our lab) moving through space at some unknown speed V...
Does the speed of light change in a gravitational field depending on whether the direction of travel is parallel to the field, or perpendicular to the field? And is it the same in both directions at each orientation? This question could be answered experimentally to some degree of accuracy. Experiment design: Place two identical clocks A and B on the circumference of a wheel at opposite ends of the diameter of length L. The wheel is positioned upright, i.e., perpendicular to the ground...
According to the General Theory of Relativity, time does not pass on a black hole, which means that processes they don't work either. As the object becomes heavier, the speed of matter falling on it for an observer on Earth will first increase, and then slow down, due to the effect of time dilation. And then it will stop altogether. As a result, we will not get a black hole, since the critical mass will not be reached. Although the object will continue to attract matter, it will not be a...
