Solving the Hermite Equation: What are the Hermite Polynomials?
  • Context: Graduate
  • Thread starter Thread starter fisico30
The discussion revolves around the Hermite equation, a second-order homogeneous linear differential equation, and the nature of Hermite polynomials as solutions to this equation. Participants explore the relationship between boundary conditions (BCs), initial conditions (ICs), and the types of solutions represented by Hermite polynomials.
  • One participant questions the specific boundary and initial conditions under which Hermite polynomials are derived as solutions to the Hermite equation.
  • Another participant provides the Rodrigues formula for Hermite polynomials and states the corresponding Hermite equation.
  • A later reply acknowledges the initial misunderstanding regarding the nature of the question about the polynomials.
  • Another participant mentions the Frobenius method as a way to generate solutions but expresses uncertainty about the relationship between general and particular solutions in the context of boundary conditions.
Participants do not reach a consensus on the specific boundary and initial conditions related to Hermite polynomials, and there remains uncertainty regarding the distinction between general and particular solutions.
Limitations include the lack of clarity on the specific boundary and initial conditions that lead to the identification of Hermite polynomials as particular solutions, as well as the unresolved relationship between general solutions and the application of boundary conditions.
fisico30
HEllo everyone,
a question about the 2nd order, homogeneous, linear diff .eqn. of order n, called the Hermite equation.
A ODE has a general solution. The BCs and the ICs specify, select a particular solution out of the general solution.
What are the Hermite polynomials? They are polynomials of different order n, that are solutions to the mentioned equation.
But under which BCs or ICs?
I can see how they solve the eqn, but I am not sure what type of solution they represent... general, particular...
thanks
fisico30
The Hermite polynomials which can be given by the Rodrigues Formula :
H[tex]_{n}[/tex](x)=(-1)[tex]^{n}[/tex]e[tex]^{x^{2}}[/tex][tex]\frac{d^{n}}{dx^{n}}[/tex]e[tex]^{-x^{2}}[/tex]
Which will be a solution to the Hermite Equation:
y''-2xy'+2ny=0
Hope this helps. We just covered this in my math for scientists class.
wow. totally just realized that you weren't asking what the polynomials solved. As far as BC's and IC's, I am not sure.
Thanks physman88.
I know that we can generate solutions via the Frobenius method. But my mind is stuck with the idea that a particular solution has to come out of a general solution once BCs are used...
