Solving the Integral present in Dirac's quantization of charge problem
The discussion revolves around computing the angular momentum of electromagnetic fields generated by an electric monopole and a magnetic monopole. The integral of interest is expressed as ∫_0^∞ (r dr) / [(r² + D² - 2Dru)^(3/2)], with attempts made to solve it using integration by parts and substitution methods. Participants suggest rewriting the denominator and breaking the integrand into two fractions to facilitate integration. A trigonometric substitution is recommended, particularly since the condition 1 - u² is confirmed to be non-negative for the problem at hand. The conversation highlights the challenges faced in solving the integral and explores various mathematical techniques to approach the solution effectively.
CmdrGuard
This problem involves an electric monopole placed at the origin and a magnetic monopole placed a distance D away, say arbitrarily, along the z-axis.
I need to compute the angular momentum of the EM fieds:
\vec{J_{field}} = \frac{1}{4\pi c}\int{d\tau \vec{r} \times (\vec{E}\times \vec{B})}
The integral is over all space. After trudging along, I am left with the following integral:
\int_0^\infty{\frac{r dr}{[r^2 +D^2 -2Dru]^{3/2}}}
If I can solve this last integral, I am home free.
All terms in the integral, other than r, are constants with respect to r.
I tried using integration by parts but was not able to get anywhere. "u" substitution taking the argument of the cube root in the denominator as "u" doesn't seem productive, either.
Unless my above two attempts were done wrong, I must say I am out of ideas.
Can anyone suggest anything?
I would try writing the denominator as
r^2-2rDu+D^2u^2 -D^2u^2 +D^2=(r-Du)^2 + D^2(1-u^2)
then try letting v = r - Du, dv = dr and see what that gets you.
Hi LCKurtz,
I can't seem to get much further with that approach as I'm left with a (v+Du)dv in the numerator and can't see where to go from there.
CmdrGuard said:
Hi LCKurtz,
And so the integrand is
\frac{v+Du}{(v^2 + D^2(1-u^2))^\frac 3 2}
right? Certainly you can break that into two fractions and do the v part of the numerator with a substitution. Doing the other part it probably makes a difference if 1-u2 is positive or negative. If it is positive that part has the form
\int \frac 1 {(v^2+k^2)^{\frac 3 2}}
and I think a trig substitution would work. And if 1-u2 is negative a different trig or maybe a hyperbolic trig substitution looks like it should work. Did you try those?
Yup.
That does it.
More specifically, 1-u^2 \geq 0, since, for my problem, u \equiv cos(\theta).
Thanks, LCKurtz.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 19 ·
