Solving this Differential Equation using Convolution
6 replies · 2K views · last reply
Jack1235
The differential equation ##5s(t)-4s''(t)=r(t)## can be solved by the convolution ##s=q*r## where ##q(t)=c_1*\exp(-c_2*|(t)|)##. Find ##c_1+c_2##.
$$\int_{-\infty}^{\infty} r(t-u)s(u) \,du$$
$s=c_1*\exp(-c_2*|(t)|)*r(t)$ But how can I solve $c_1+c_2$ ?
Hello Jack,
:welcome:​
I am very much afraid your post will be deleted by one of the mentors soon: it doesn't comply with the PF rules and guidelines (there is no posted apparent effort from your side).
Before that: ##\LaTeX## has to be enclosed by double $$ (for displayed math) and double ## for in-line math:
The differential equation $$5s(t)-4s''(t)=r(t)$$ can be solved by the convolution $$s=q*r$$ where $$q(t)=c_1*\exp(-c_2*|(t)|)$$. Find $$c_1+c_2$$
Relevant Equations: $$\left (\int_{-\infty}^{\infty} r(t-u)s(u) \,du\right )$$
$$s=c_1*\exp(-c_2*|(t)|)*r(t)$$ But how can I solve $$c_1+c_2$$ ?
With ## it looks better:
Homework Statement: The differential equation ##5s(t)-4s''(t)=r(t)## can be solved by the convolution ##s=q*r## where ##q(t)=c_1*\exp(-c_2*|(t)|)##. Find ##c_1+c_2##.​
Relevant Equations: ##\int_{-\infty}^{\infty} r(t-u)s(u) \,du##​
##s=c_1*\exp(-c_2*|(t)|)*r(t)## But how can I solve ##c_1+c_2## ?​
So this is my attempt: ##5(q*r)-4(q*r)''=r(t)## and ##5(C_1\exp(-C_2|t|)*r)-4*(C_1*\exp(-C_2*|t|)*r)''=r(t)##
In addition to that: ##(q*r)''=(-i*2*\pi*\widehat{ts}(\nu))'##
Since the OP has (belatedly) shown some effort, no moderator action has been taken here.
Good. Now, do I have to sort out when a * stands for multiplication and when it means convolution ?
I also find it strange the problem statement asks for ##c_1 + c_2##. It seems to me they have different dimensions and can not be added. Could it be the problem composer means to ask for ##c_1## and ##c_2## ?
Furthermore: the relevant equation does not really look like an equation at all.
I suppose you meant $$s = q*r \ \ \Leftrightarrow \ \ s(t) =\int_0^t q(\tau) r(t-\tau) \, d\tau \ \ ?$$
Could you please also explain what you do in post #3 ?
Note: I tweaked the first post to get most of the LaTeX to render.
Then post #2 now looks pretty dumb ...:biggrin:
