Solving tri-linear interpolation parameters
The discussion focuses on solving for the tri-linear interpolation parameters (Xd, Yd, Zd) within a hexahedron defined by eight 3D vector points. The user seeks to determine these parameters given a known interpolated point C and the tri-linear interpolation equation. They mention that while they can derive equations for Z, they are struggling to combine the equations for X and Y effectively. The conversation highlights the complexity of the interpolation process and the need for a systematic approach to solve the equations simultaneously. The user is looking for guidance on the safest method to combine these equations to find the desired parameters.
aadster
I'm trying to find the tri-linear interpolation parameters of a point C within a hexahedron of 3d vectors (C000, C100, C010, C011 etc)
You could call this "inverse tri-linear interpolation"
Ive used the same variable names as this wikipedia article: http://en.wikipedia.org/wiki/Trilinear_interpolation
if Xd, Yd & Zd are the 0..1 trilinear parameters for x,y & z respectively, how can I solve the equations for these parameters? The interpolated point C is known.
Many thanks
to break this down further, this is the tri-linear equation.
R = ((1-Yd) * (p000 * (1-Xd) + p100 * Xd ) + (p010 * (1-Xd) + p110 * Xd ) * Yd) * (1-Zd) +
((1-Yd) * (p001 * (1-Xd) + p101 * Xd ) + (p011 * (1-Xd) + p111 * Xd ) * Yd) * Zd;
where R is tri-linear interpolated result,
P000-P111 are the 8 points of a hexahedron that define the 3D interpolation space
R and P can be either scalar or vector
Xd, Yd, and Zd are scalars and are the tri-lin parameters I am trying to find
Known:
When Xd,Yd & Zd = 0, R = p000 and when Xd,Yd & Zd = 1, R = p111 etc
Clearly there are some degenerate cases here, but my maths is a little rusty and I am finding tricky to solve for R... any ideas? Thanks!
I'll add to this as I progress, but interestingly Wolfram Alpha could only solve this for the simplest factor Z: (only 2 occurances)
Z = (a X Y+a (-X)-a Y+a-b X Y+b X-c X Y+c Y+d X Y-R)/(a X Y+a (-X)-a Y+a-b X Y+b X-c X Y+c Y+d X Y-e X Y+e X+e Y-e+f X Y-f X+g X Y-g Y-h X Y)
Since factors a-h form a cube of values, I can swap them around to create two other equations in the exact form above wrt X and Y.
Assuming I have all 3 equations, what is the safest way to combine all 3 equations to calculate X, Y & Z?
Thread 'How to define a vector field?'
Hello! In one book I saw that function ##V## of 3 variables ##V_x, V_y, V_z## (vector field in 3D) can be decomposed in a Taylor series without higher-order terms (partial derivative of second power and higher) at point ##(0,0,0)## such way: I think so: higher-order terms can be neglected because partial derivative of second power and higher are equal to 0. Is this true? And how to define vector field correctly for this case? (In the book I found nothing and my attempt was wrong...
  • · Replies 47 ·
  • · Replies 21 ·
  • · Replies 25 ·
