Solving Umax with Pmax and Ohms
  • Thread starter Thread starter Ren_Majer
    Ohms
The discussion focuses on solving a physics problem involving two resistors in series, each with a maximum power rating of 0.25 W. The resistors, R1 (120Ω) and R2 (180Ω), require calculations to determine the maximum voltage that can be applied without exceeding their power limits. The participant expresses a need for step-by-step explanations due to a lack of confidence in math and physics. The calculations provided indicate how power is dissipated in each resistor when a specific current is applied, emphasizing the importance of understanding thermal limits in series circuits. The conversation highlights the necessity of clear guidance for those relearning physics concepts.
Ren_Majer
Brief personal intro, I have last time studied physics about 12 years ago.
I am now starting in 2 weeks time in a university and there is mandatory physics course so I am trying to relearn and learn as much as I can before that time.
For that reason I am trying to solve textbook tasks from my old physics books.
I have never been good at maths nor physics atleast not calculations. Thus I appreciate thorough-Step by Step explanations so I can understand the solution.
Thank you for your time
How large voltage U , can be attached to the circuit , when both the resistance have an Pmax of 0,25 W ?
R1 = 120Ω
R2=180Ω
They are in series.
Answer is :
Umax = 11
P = U * I
U = R * I
0,25*120= 0,002083333333
0,25*180= 0,003888888889
0,002083333333 + 0,003888888889=0,00347222222
0,00347222222*120 = 0,416666664
0,00347222222*180 = 0,624999996
4,16666664+6,24999996= 10,41666666
Since they're in series, they have the same current through them. If you start with a low current and slowly ramp it up, do you know which of the resistors will reach its thermal limit first?
No , it is not mentioned on the task nor which direction the current will go
Just assume that you can control the current through the resistors, I promise you that I'll get to the point shortly :smile:
Say you have a current of 1 A through the resistors. How much power is then dissipated in each resistor?
  • · Replies 21 ·
12K
