Some clarifications on my proving
  • Thread starter relinquished™
In summary, the conversation discusses the proof of the proposition "If a set S is dense, then every point in S is an accumulation point of set S". The conversation also clarifies the definition of denseness and the assumption that S is dense in the set of real numbers. The proof involves assuming the contrary and showing that it leads to a contradiction, thus proving the proposition. The question arises about the placement of a and b in the deleted ε-neighborhood of x and the discussion concludes that they are not in the neighborhood and this fact helps in proving the proposition.
relinquished™
79
Hello. I didn't know if this is the right forum to post this (since this is the Calculus section and my question pertains to real analysis), but I would like some clarifications on a proof I am preparing for the propositon "If a set S is dense, then every point in S is an accumulation point".
What I did is assume the contrary, that is, "If a set S is dense then none of its points are accumulation points". Then for an arbitrary element x in S it is possible to create a deleted ε-neighborhood for any ε>0 such that (x-ε, x+ε) does not contain any point in S. Now, i let a and b be elements in S such that a < x < b such that x-a = b-x. If I assign ε=b-x (in turn, ε=x-a), then the deleted neighborhood for this choice of ε must be empty to guarantee that x is not an accumulation point, that is, (a,x)U(x,b) should be empty, which means (a,x) is empty and (x,b) is also empty. This means that there are no numbers between a and x and between x and b, which means that S is not dense (since a dense set is defined to be that for any elements c and e and c<e there exists an element d such that c < d < e), which leads to a contradiction since we assume S to be dense. Hence, If a set S is dense, then every real point in S is an accumulation point. ///
My questions are:
(1) can I simply assume that x is between a and b since S is dense?
(2) If I choose my ε to be b-x, are a and b in the neighborhood of x? this also leads to the question that are deleted neighborhoods open sets...
Thanks for any help.
What do you mean by "a set S is dense"? I know what it means to say that a set is dense in some larger space. Do you mean dense in the real numbers? You appear to be assuming that S is a set of real numbers. And do you mean to say, then an accumulation point of the set of real numbers?
From what I understand, he/she is saying that S is dense in the set of real numbers... continuing further, if a and are real nos. and a < b, there is an s belonging to S such that a < s < b.
This section is called "Calculus & Analysis" so it looks like a good place.
As has been mentioned Set density is with respect to another set
as in S is dense it S'
next the contrary to
"If a set S is dense, then every point in S is an accumulation point."
is
"If S there exist a one point in S that is not an accumulation point, then S is not dense."
so (assuming you mean S is dense in R)
Let x be a point in S that is not a point of accumulation and show that S is not dense.
You are on the right track
I do not understant this
neighborhoods are open sets
deleted neighbor hoods are open
unions of open sets are open and a deleted neighborhood is a union of open sets in R1.
HallsOfIvy
Sorry for not making the definition of Denseness clear. Irony of Truth just spelled it out for me: S is dense in the set of real numbers... continuing further, if a and are real nos. and a < b, there is an s belonging to S such that a < s < b.
Also, the propostition should be: "If a set S is dense, then every point in S is an accumulation point of set S".
Sorry again for the incompleteness of my statements and proposition.
Irony_Of_Truth
I'm a he ^_^;; Thanks by the way for clearing things up.
lurflurf
When I meant "can I assume that a < x < b" I was asking if I could assume that x will be between two numbers, sa a and b, that is in set S such that a < x < b because of the Denseness of S
Generally, the thing I'm bothered with is whether or not a and b should be in the deleted ε neighborhood of my arbitrary point x under the assumption that a < x < b, that x-a = b-x and if my chosen ε > 0 would assume a value of ε=x-a (in turn, ε=b-x).
I would also appreciate it if anyone can find any potholes in my proof :)
Thanks in advance :)
relinquished™ said:
lurflurf
well you have found that
x is not an accumulation point-> there exit (a,x)U(x,b)
thus S is not dense
clearly a and be are not is (a,x)U(x,b)
(you could also say intersection((a,b),S)={x})
you need not be concerned about denseness other than showing since x is not a point of accumulation S is not dense.
I do not see how assuming S dense helps
sketch of proof
1) let x in S not be a point of accumulation
2) then there exist a deleted neighbor of x with nothing in common with S
3) S is not dense in R because (a,x) does not cointain a point in S
you should not say (a,x) is empty (though perhaps you could if your universe were S) it is better to say (a,x) contains not points from S.
I see... a and b are not in the deleted ε neighborhood of x when ε=x-a. Thanks for the clarifications. :) I really appreciate the help :)
What is the purpose of "Some clarifications on my proving"?
The purpose of "Some clarifications on my proving" is to address any questions or concerns that may have arisen during the process of proving a hypothesis or conducting an experiment. It allows the scientist to clarify any misunderstandings and provide additional information that may be necessary for a better understanding of the results.
Why is it important to provide clarifications on a proving?
Providing clarifications on a proving is important because it ensures the accuracy and validity of the results. It allows for a full understanding of the methods and procedures used, as well as any limitations or potential biases that may have affected the outcome. This transparency is essential for the scientific community to evaluate and replicate the study.
What kind of information should be included in "Some clarifications on my proving"?
The information included in "Some clarifications on my proving" should cover any key aspects of the study that may have been unclear or need further explanation. This may include the methodology, data analysis, results, and conclusions. Additionally, any potential sources of error or limitations of the study should also be addressed.
Who should read "Some clarifications on my proving"?
"Some clarifications on my proving" should be read by anyone who has a vested interest in the study, such as fellow scientists, researchers, or those in related fields. It can also be beneficial for the general public to gain a better understanding of the study and its implications.
When should "Some clarifications on my proving" be provided?
"Some clarifications on my proving" should ideally be provided after the initial publication of the study, when questions or concerns may arise. However, it can also be provided at any point during the research process if needed.
  • Calculus
  • Calculus
  • Calculus
