Some conceptual collision/energy stuff
  • Thread starter Thread starter lollol
    Conceptual
Mechanical energy can indeed be negative, as it is defined relative to an arbitrary reference point for potential energy. The total mechanical energy, which is the sum of kinetic and potential energy, can take on negative values based on this reference. In terms of collisions, the type of collision—elastic or inelastic—affects the distribution of energy and momentum but does not inherently determine the damage caused; rather, the vehicle's structural integrity plays a crucial role. Understanding these concepts is fundamental in physics, as they relate to how energy is conserved and transferred during collisions. Overall, both mechanical energy and collision dynamics can be complex but are grounded in basic principles of physics.
lollol
1) I was thinking about the definitions of KE and PE... can't the values KE and PE only ever be positive...? so
ME = KE + PE
Can total mechanical energy ever be negative? I'm thinking it cannot
2) also let's say you're in a car and you collide with another car... I'm trying to compare the impact of an inelelastic vs. elastic collision.. which would actually cause more damage to you? if the cars stick... or if they rebound?
I'm really clueless on this
1] Mechanical energy is somewhat relative to a reference point. Like, if you consider that a level 1000km above you has potential energy 0, then your P.E would be hugely negative and if you are at say.. rest.. your KE will be '0' and mechanical energy will hence be negative.
2] It doesn't really matter what kind of collision you are in but what really matters is how your vehicle gives into the stress. The type of collisions that u mention controll/predict only the final velocities and trajectories of the bodies colliding. For safety data, you need to know the yield strength and similar parameters for your vehicle.
This is basic, basic high school physics.. and I was going through the textbook, these were just conceptual questions to think about
1) It just asked if mechanical energy can be negative
2) It simply asked if an inelastic or an elastic collision would cause more damage
you're thinking too much IMO. There is a definitive answer... this is basic high school level physics
With an elastic collision we can think of the momentum being distributed equally, atomically. If an elastic impact yielded .00000001 Newtons per atom, we could not make the same generalization about an inelastic collision.
Yes, it can. For two reasons: one is a bit silly, and comes from the fact that you can define your "0" for potential energy just anywhere: potential energy is defined up to an arbitrary constant. For instance, the potential energy in a uniform gravity field with acceleration g of a mass m is usually written as: V = m x g x h, where h is the "height" (but measured from where ?). But you can just as well write: V = m x g x h + C, where C is an arbitrary constant. You can even see this C as meaning that you took another reference point for your "h".
So total mechanical energy, being KE + V, is also defined up to an arbitrary constant (the one in C). So you can give it any value, positive or negative, to your liking.
But another reason is "more serious". By convention, one usually takes potential energy to be 0 at "infinite separation". IF you take this convention, then negative total energy means that you have a "bound state": that not all the particles/constituents of your system can get arbitrarily far away from each other, but that at least some need to stay "together".
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Hello everyone, Consider the problem in which a car is told to travel at 30 km/h for L kilometers and then at 60 km/h for another L kilometers. Next, you are asked to determine the average speed. My question is: although we know that the average speed in this case is the harmonic mean of the two speeds, is it also possible to state that the average speed over this 2L-kilometer stretch can be obtained as a weighted average of the two speeds? Best regards, DaTario
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
