How Do You Tackle Complex Derivative Problems?
  • Thread starter Thread starter Emethyst
    Derivative
The discussion focuses on tackling complex derivative problems, specifically three functions involving logarithmic and exponential derivatives. For the first function, y=x^lnx, the correct derivative involves applying the chain rule and recognizing the need for the factor of 2 that arises from differentiating ln(x)^2. The second function, y=(1+x)^1/x, presents similar challenges, with participants struggling to simplify their initial answers to match the correct form. The third function, a more complicated quotient, raises questions about the efficiency of using the quotient rule versus other methods. Overall, participants emphasize the importance of mastering derivative rules and applying them correctly to solve these challenging problems.
Emethyst
Find the derivatives for the following questions: a) y=x^lnx b) y=(1+x)^1/x c) y=((x-1)^2e^2x)/((x^2+1)^2(x^3-10)^3)
Derivatives for exponential equations, the natural logarithm and derivative rules
For a) I came up with an answer of (x^lnxlnx)/x, however, this is not the correct answer as it should be 2(lnx)x^lnx-1. I know where the x^lnx-1 came from, I am just lost on how that 2 got there.
b) is much the same as a) for me, as my answer of -((1+x)^1/xln(1+x))/x^2 is not close to the correct answer of (((1+x)^1/x)/x^2)((x/(1+x))-ln(1+x)). I don't know if my problems here are stemming from simplification or if I simply overlooked something when solving.
For c), basically I have no idea how to solve this one :-p My first try was to use the quotient rule, but this resulted in a HUGE amount of work, and got me thinking that there might be an easier way to solve it. Is there an easier way to solve this question, or is the quotient rule the only way to go about it?
Any help you guys can give for these questions will be greatly appreicated, thanks in advance.
for random functions u , v we have
(u o v)'= (u' o v).v'
(uv)'=u'v+v'u
(u/v)'=(u'v-v'u)/v²
(u^n)'=nu'u^(n-1)
(exp u)'=u'exp u
(ln u)'= u'/u
okay now all you have to do is practice .until you master it.
PS: (u o v) means u(v(x)) for any x.
and (something)' = derivative of something.
I know all of the derivative rules, my problems here are stemming from actually applying them to the questions I have posted.
A common trick when differentiating a function, say f(x), that has a function of x in the integrand is to write f(x) as e^(ln(f(x))). In problem a) for example, this would be e^(ln(x^ln(x))), which by properties of logs is the same as e^(ln(x)*ln(x)) = e^(ln(x)^2). So when you differentiate this you will use the chain rule and will have to differentiate ln(x)^2-- this is where the 2 comes from.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 25 ·
  • · Replies 24 ·
