Some more electromagnetism questions (ac generators)
The discussion focuses on calculating the magnetic flux density and output voltage of an AC generator. An AC generator with a coil area of 120 cm² and 100 turns produces a peak voltage of 29V at 6000 RPM. When the rotation rate is reduced to 3600 RPM, the new peak output voltage and frequency need to be determined, with the original frequency calculated as 100Hz. Additionally, the discussion involves calculating the angular speed of a semicircular wire in a magnetic field with a flux density of 0.8T, generating a peak EMF of 0.31V.
  • Understanding of electromagnetic induction principles
  • Familiarity with the formula EMF = ωNABsinθ
  • Knowledge of AC generator operation and characteristics
  • Basic skills in calculus and physics for solving equations
  • Research the relationship between RPM and output voltage in AC generators
  • Learn about calculating magnetic flux density in electromagnetic systems
  • Study the effects of angular speed on EMF generation in rotating conductors
  • Explore the principles of alternating current and frequency in electrical engineering
Students and professionals in electrical engineering, physics enthusiasts, and anyone involved in the design or analysis of AC generators and electromagnetic systems.
KatieKangaroo
A few more questions that i am stuck with:
An AC generator has a coil area of 120cm². The coil has 100 turns. The generator produces a peak voltage of 29V when the coil is turning at 6000 revolutions per minute.
Calculate the magnetic flux density (assumed uniform) required.
The rate of rotation is reduced to 3600 revolutions per minute.
Calculate the new peak output voltage and the new output frequency. (I calculated the old frequency before and found that it was 100Hz).
A wire is bent into the shape of a semicircle of radius 0.2m. A uniform magnetic field which has a flux density of 0.8T acts normally to the plane of the semicircular wire. As the wire is rotated at a constant rate it generates an alternating EMF with a peak value between the terminals 0f 0.31V Calculate the angular speed at which the wire is rotated.
Ive been trying to use the formula EMF = ωNABsinθ but without success.
Sorry, I am just having trouble answering these without a teacher to help :redface:
Thanks again for any help in advance.
The formula for EMF you are using seems reasonable. Maybe it's your math, so if you could write out some of your calculations.
10K
  • · Replies 26 ·
