Some questions about Faraday heaping
  • Context: Undergrad
  • Thread starter Thread starter hchs9818
    Faraday
9 replies · 6K views
hchs9818
Here is a a simply description:
When a container filled with mustard seeds(small sphere) is vibrated vertically with a frequency between 1 - 10 Hz,we see Faraday heaping occurs.
I want to know how do I design a experiment to investigate this phenomenon?
We have problems in making a vibrator to make frequency between 1-10Hz?
Thank you very much for your help!
Yours truly,
Christina.
Audio speaker or sub-woofer and an adjustable audio source such as LabView. Office Depot has "off the shelf" computer speaker systems for cheap.
In a hurry? Get a one or more speaker(s) as a vibration table, connect it to a computer and use an audio generating program like LabView to control sound vibrations. If you want you could borrow a complex wave generator from a lab or build something exotic or just check out this link:
http://cnx.org/content/m15510/latest/ http://cnx.org/content/col10507/latest/
Please forgive me if this is still too much to do. Hopefully this will at least give you ideas and then maybe someone else has an easier solution?
Wishing you all the best on your project!
Please let us know how it turns out - Thanks!
Thanks a lot for you help!
But I wonder can a speaker vibreate a bottle of mustard seeds?
Really appretiate for you help^^
You might want to try an electric motor driving an unbalanced wheel and fed with a variable power supply.A low voltage motor should do the job eg a d.c. motor powered by a battery through a variable resistor.
I'm from China.I don't speak good English——I hope you understand my words.I'm also working on this problem and I am building a machine to help solve the problem.However,I didn't observe the phenomenon that was supposed to happen when I just vibrated it by my own hands.I wonder under what condition can one observe the phenomenon.Can you tell me if you have once observed the phenomenon? Maybe we can co-operate on this.Looking forward to your reply.
Yours truly,Christina.
Hi,Christina:
I think you need a certain facility to finish the experiment. There are many kinds of vibrating machines. You can choose a vertical-vibrating machine. The frequency is a very important parameter. Maybe you have to do the same experiments under different frequency. So a steady frequency is necessary.A number of audio speakers can't offer a steady and exact frequency.
Hi,Chinese:
我想过这个问题,怎么去振动容器。容器应该是密闭的。我认为振动的时候应该是正弦x=Asint的受迫振动。这样的振动比较简单好分析研究,而且具有周期性。有很多振动器都是正弦型的。而且振幅也是个问题,振幅应该和粒子的大小有一定关系的时候现象比较明显。
我以前想过能不能用匀速率,就是速度大小不变,瞬间很快的改变速度方向,但是好像在短时间高频率的情况下这种条件不好实现。而且找了找仪器也是正弦的比较多见。你是不是在准备CUPT?
以上都是我的猜测。
hello chiristina I am amir
now i have this problem , like you if you can ,and if you want to help me , you can email me
i write my email down:
armojaveri@gmail.com
