Can You Solve These Vector Questions About Wind?
  • Thread starter Thread starter uniquegirl
    Vector Wind
To solve vector questions about wind, participants are encouraged to draw vector diagrams and show their work to receive assistance. The discussion emphasizes the importance of understanding trigonometric functions and their application in finding velocity components, specifically using sine and cosine for right triangles. Participants are advised to avoid guessing and instead apply learned principles to derive solutions. The conversation also highlights the need for clarity in calculations and the importance of maintaining proper units throughout the problem-solving process. Overall, the thread aims to guide users in developing a deeper understanding of vector analysis in physics.
  • #31
uniquegirl said:
But since Ve isn't given, would it be 25? or am I missing something?
Look at the triangle formed by the red arrow, the vertical blue arrow, and the dashed line across their tops. In relation to the 25°, the blue arrow is the adjacent, the dashed line is the opposite and the red arrow is the hypotenuse.
Which ratio do you want in order to find Vn from V? What is that ratio as a trig function of the 25°?
Likes Lnewqban
  • #32
Ve isn't given but is not equal 25. 25 is the hypotenuse. Ve is one of the vertical sides, the opposite to the angle of 25 degrees and the adjacent side is Vn .
If i give you a right triangle with the hypotenuse equal to 25 and one angle equal to 25 degrees, can you find the side adjacent to the angle of 25 degrees?
Likes Lnewqban
  • #33
Yup!
Likes Delta2
  • #34
uniquegirl said:
Yup!
ok so what will be the adjacent side if the hypotenuse is 25 and the angle is 25 degrees? And what will be the opposite side?
  • #35
sin(25)= 0.4226...
0.4226... = d / 25
Swap sides:d / 25= 0.4226...
Multiply both sides by 30:d = 0.4226...x 25
Calculate: d = 10.56 to 2 decimal places
So opp would be 10.56?
Is this it?
  • Love
Likes malawi_glenn and Delta2
  • #36
yes and what will be the adjacent?
  • #37
Sin A= √(c^2-b^2)
SinA= √(25^2-10^2)
Sin= 22.91
Likes Lnewqban and Delta2
  • #38
have you not worked with right-angled triangles and trigonometry before in basic math?
hyp = 25 (total velocity)
adj = vn (velocity component in the north direction)
opp = ve (velocity component in the east direction)
opp /hyp = sin25°
adj /hyp = cos25°
Or, perhaps this is easier
adj = ve (velocity component in the east direction)
opp = vn (velocity component in the north direction)
opp /hyp = sin65°
adj /hyp = cos65°
  • #39
uniquegirl said:
Sin A= √(c^2-b^2)
SinA= √(25^2-10^2)
Sin= 22.91
Yes ok you can use pythagorean theorem, but you could do it as 25*cos(25)
Likes uniquegirl
  • #40
oh ok thank you! so 22.91 is the right answer? So the answer for Ve is the same as the answer for Vn, because they are same triangles?
  • #41
Assuming Ve is 22.91,for question b this is what I did, feel free to correct me
Question b- A strong gust of wind from the west causes the skier to accelerate to the east at 2.0 m s-2 for 1.8 s. Calculate the new velocity in the easterly direction
vi=22.65ms-1 t= 1.8s a=2.0ms^2 vf=?
vf=vi+at
vf= 22.65+2.0x1.8
vf= 26.25
  • #42
No Ve is the opposite site , Vn is the adjacent side, the answer for Ve you calculated it as 10.24.
  • #43
vf=vi+at
vf= 22.65+2.0x1.8
vf= 26.25
this would have been correct if you had used as vi=25sin(25)=10.24.
  • #44
Is this better? vf= 10.56+2.0x1.8 vf= 14.16
Likes Delta2
  • #45
C) Use your answer in (a) to calculate the size and direction of the new resultant velocity of the skier
so for direction I used tan-1=opp/hyp =10.56/25 = 0.4424 I think I did this wrong cause its such a low number but for the size, V^2= 25^2+10.56^2.
  • #46
uniquegirl said:
tan-1=opp/hyp
the tangent of an angle is not opp/hyp
  • #47
tan-1= opp/adj
= tan-1 10.56/22.91
Likes malawi_glenn
  • #48
For the size, I used v=(square root ) a^2+b^2
v= (square root)22.91^2+10.56^2
would this be right?
  • #49
The 22.91 is inaccurate. That is because in post #37 you used ve=10 instead of 10.56. (Or, better, using vn=25cos(25).)
Assuming you are trying part c, using 10.56m/s as the Easterly velocity here just gets you back to a net speed of 25m/s. You need to be using the new Easterly velocity calculated in post #44.
Please try to change your way of working to be entirely algebraic as far as possible, only plugging in numbers at the end. This has many advantages, such as fewer errors, easier detection of errors, improved precision and greater readability. In multipart questions, that even means not immediately using the numerical answer to one part in the next part, instead resuming the algebraic form. Sometimes that let's you do some cancellation.
When you do plug in numbers, always include the units.
To illustrate:
Part a:
ve=v sin(25)=25m/s sin(25)= 10.56 m/s.
vn=v cos(25)=25m/s cos(25)= 22.66 m/s.
Part b:
ve'=ve+at=ve+(2m/s2)(1.8s)= 14.16 m/s.
Part c:
v'=√(ve'2+vn2)
etc.
Now, what about the last bit, the new direction?
Likes uniquegirl and Lnewqban
  • #50
Cool, Thank you for all the help everyone, appreciate it:smile:
Likes Lnewqban
  • · Replies 26 ·
