Sound in an Open Vertical Tube partially filled with Water
The calculations for sound in an open vertical tube partially filled with water are confirmed to be correct. The wavelength is determined to be 59 cm, which converts to 0.59 m. The frequency of the sound wave is calculated as approximately 581.36 Hz using the speed of sound at 343 m/s. The length of the air column is calculated to be 221.25 cm. It is emphasized that answers should be rounded to three significant figures due to the precision of the given values.
fjccommish
An open vertical tube has water in it. A tuning fork vibrates over its mouth. As the water level is lowered in the tube, the seventh resonance is heard when the water level is 191.75 cm below the top of the tube.
a What is the wavelength of the sound wave? The speed of sound in air is 343 m/s. Answer in cm.
b What is the frequency of the sound wave (the tuning fork) in Hz?
c The water continues to leak out of the bottom of the tube. When the tube next resonates with the tuning fork, what is the length of the air column? Answer in cm.
L = [(2n-1)w]/4
w = wavelength, n is resonance #
I think this is correct. Please verify.
a
L = (2n-1)w/4 so w = 4L/13
w = 4(191.75)/13 = 59 cm
b
59cm is .59m
f = v/w = 343/.59 = appox 581.36 Hz
c
L =(2*8-1)*59/4 = 15*59/4 = 221.25cm.
All looks good to me.
Thank you.
Can I add this...
The question gives the length of the air column to 5 significant figures (191.75 cm) and the speed of sound to 3 sig. figs. (343 m/s).
Your answers should be rounded to 3 sig. figs.
(Getting this wrong in an exam’ could cost you a mark.)
Thanks.
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
