How Does Sound Behavior Change in Low Atmosphere?
The speed of sound, referred to as Mach 1, varies with altitude due to changes in temperature in the atmosphere. As altitude increases, the speed of sound is influenced by the density and pressure of the air, leading to different behaviors in sound propagation. The intensity and frequency of sound also change with altitude, although specific details on these variations were not extensively covered in the discussion. For further understanding, refer to Mach vs. Altitude Tables and resources on mechanical waves.
  • Understanding of atmospheric layers and their properties
  • Basic knowledge of sound waves and their characteristics
  • Familiarity with temperature's effect on gas behavior
  • Access to Mach vs. Altitude Tables for reference
  • Research the relationship between temperature and sound speed in different atmospheric layers
  • Explore the effects of altitude on sound intensity and frequency
  • Study the principles of mechanical waves and sound propagation
  • Examine the Feynman Lectures on sound behavior in various mediums
Students of physics, atmospheric scientists, and anyone interested in the properties of sound in varying atmospheric conditions.
brendanbarnes
There is no sound in space because there are not enough particles to transmit the pressure wave. But what about really high in the atmosphere where there is just a little air? Would sound move faster, slower or at the same speed? Would the intensity (aka volume) go up, down, or stay the same? And would the frequency go up, down, or stay the same as it traveled through space?
Here are some references that I have personally looked at that might spark good thoughts:
http://www.feynmanlectures.caltech.edu/I_47.htmlhttps://www.khanacademy.org/science...ve-speed-of-sound-in-solids-liquids-and-gases
Thanks,
Brendan
Likes physlosopher
The speed of sound does change as altitude increases. That speed is called Mach 1. How it changes depends a lot on how the temperature changes. So its behavior changes in different parts of the atmosphere. See Mach vs. Altitude Tables .
Thread 'A high school physics problem demonstrating relative motion'
I remembered a pretty high school problem from kinematics. But it seems it can help even undergraduates to develop their understanding of what a relative motion is. Consider a railway circle of radius ##r##. Assume that a carriage running along this circle has a speed ##v##. See the picture. A fly ##M## flies in the opposite direction and has a speed ##u,\quad |OM|=b##. Find a speed of the fly relative to the carriage. The obvious incorrect answer is ##u+v## while the correct answer is...
  • · Replies 34 ·
  • · Replies 49 ·
11K
  • · Replies 48 ·
13K
  • · Replies 31 ·
