Calculating Sound Intensity and Pressure Variation at a Distance
To calculate the sound intensity level in decibels at a distance of 100m from a 10 W speaker, the intensity I is found using the formula I = P/(4πr²), resulting in 7.96 × 10^-5 W/m². The standard reference intensity I0, used for calculating sound levels, is typically 10^-12 W/m², representing the threshold of hearing at 1000 Hz. The sound intensity level in decibels can then be calculated using the formula β = (10 dB)log(I/I0). The maximum pressure variation at that distance can also be derived from the intensity value. Understanding these calculations is essential for accurately assessing sound levels in various environments.
Ian Baughman
A speaker blares out music with a power of 10 W. Assuming the air has a temperature of 50°F and a pressure of 1 atm, what is the sound intensity level in decibels at a distance of 100m away? What is the maximum pressure variation at that point? What is the distance at which the intensity is 50 dB? The air has an effective molar mass M = 28.8 g and a ratio of heat capacities γ = 1.40.
[/B]
1) I = P/(4πr2)
2) β = (10 dB)log(I/I0)
1) I used equation #1 where P = 10 W and r = 100 m to find:
I = 7.96 ×10-5 W/m2
2) This is where I'm having difficulty. I'm not quite sure on how to find I0. I know I can't use the above equation but I can't seem to find any other information that would be helpful.
I0 is a standard value of intensity that should be given in your textbook or notes.
So I found a value, I0 = 10-12 W/m2. Where does this value come from though?
Likes Ian Baughman
Thank you!
Thread 'Correct statement about size of wire to produce larger extension'
The answer is (B) but I don't really understand why. Based on formula of Young Modulus: $$x=\frac{FL}{AE}$$ The second wire made of the same material so it means they have same Young Modulus. Larger extension means larger value of ##x## so to get larger value of ##x## we can increase ##F## and ##L## and decrease ##A## I am not sure whether there is change in ##F## for first and second wire so I will just assume ##F## does not change. It leaves (B) and (C) as possible options so why is (C)...
