Sound power, amplitude, frequency, and decibels
  • Context: Undergrad
  • Thread starter Thread starter ngn
    Power Sound Wave
The discussion centers around the relationship between sound power, amplitude, frequency, and decibels, exploring how these factors interact in the context of sound waves. Participants examine whether sound power is influenced by both amplitude and frequency, and why frequency appears to be disregarded in decibel calculations.
  • Some participants assert that sound power depends on both amplitude and frequency, while others claim it only depends on amplitude.
  • One participant references a source indicating that the power of a mechanical wave is proportional to amplitude and angular frequency, questioning the type of amplitude being considered.
  • There is a discussion about whether decibels are calculated from root-power quantities like sound pressure, which may incorporate frequency effects, while displacement amplitude does not.
  • A participant suggests using an analogy with electromagnetic waves to explain the relationship between pressure, velocity, and power in sound waves.
  • Questions arise regarding whether decibel calculations represent power or merely a ratio of amplitudes and sound pressures.
  • Another participant notes that electrical power from a microphone is proportional to sound power, indicating a relationship between voltage and sound power density.
Participants do not reach a consensus on whether sound power is influenced by frequency or solely by amplitude, and the discussion remains unresolved regarding the implications for decibel calculations.
Participants express uncertainty about the definitions of amplitude and the types of measurements used in calculating decibels, highlighting potential limitations in their understanding of how these factors interact.
ngn
TL;DR
If time-averaged power of a sinusoidal wave is proportional to the square of the amplitude of the wave and the square of the angular frequency of the wave, then why do decibels measurements only require an amplitude?
Hello,
It has been difficult to find a clear answer to this question. I've found some sources stating that the power of a sound wave depends upon both amplitude and frequency. I've found other sources stating that the power of a sound only depends on amplitude. I've found sources stating that power only depends on amplitude (and not frequency) for electromagnetic waves, but with mechanical waves (e.g., sound) both amplitude and frequency are important. And, I've found sources stating that amplitude and frequency only affect power with light waves but with sound waves, only amplitude matters.
If both amplitude and frequency are important for calculating the power of a sound wave, why is it that when it comes to calculating decibels, frequency does not matter? For example, if a 500 Hz and a 1000 Hz pure tone both have the same RMS normalized amplitude measurement (e.g., 0.50), then they both have the same decibel measurement (20*log(0.50) = -6 dB FS). Similarly, if a 500 Hz and 1000 Hz tone both have the same sound pressure (e.g., 10 Pa), then they both have the same dB SPL (20*log(10/.000020) = 114 dB SPL). The fact that you calculate decibels on amplitude-based measurements only suggests that frequency is not important in calculating power. Is this correct?
Can you cite your source for this statement?
Here is one source:
https://pressbooks.online.ucf.edu/osuniversityphysics/chapter/16-4-energy-and-power-of-a-wave/
There is a description of how the power of a mechanic wave is proportional to the amplitude and angular frequency. What amplitude measure is being considered here? I can understand this on some level because if the amplitude of displacement is considered, then yes, if a higher frequency wave and a lower frequency wave both have the same amplitude of particle displacement then the higher frequency wave will be more powerful because the particles travel greater distance in the same amount of time. What I don't understand is why that is not considered when calculating decibels from typical measures of amplitude.
One reason I was thinking is that displacement may not be a root-power quantity (i.e., we don't typically calculate decibels from displacement amplitude), and decibels are only calculated on root-power quantities like sound pressure, and sound pressure "controls" for frequency because it's based on particle velocity, which has frequency built into the measure. In other words, if a high frequency and low frequency sound have the same sound pressure, then the displacement of the higher frequency sound must be less than the displacement of the lower frequency sound (because their particle velocities are the same at equal pressure). Does this also apply to calculating decibels from normalized measures in a WAV file? Are those voltages? And do voltages have frequency built into the amplitude measure as well? A simple way to think about these issues will be helpful.
Maybe use an EM wave on an infinite transmission line as an analogy? In this case, the voltage and current waves are in-phase, and the power is just I*V. With sound, the pressure and velocity are roughly analogous to voltage and current, so to find power we can multiply them, or alternatively, if we know the properties of the medium, we can find the power from one of them. This is like finding the transmission line power from V^2/Z or I^2*Z, where Z is the characteristic impedance. For sound, power = velocity^2 * Z or pressure^2/Z.
When the frequency is altered, for the electrical case V and I do not alter, and for the sound case, pressure and velocity do not alter. But if you consider a transmission line, at low frequencies more charge is given to the conductors during each half cycle, because current flows for greater duration. So charge is dependent on both voltage and inversely with frequency. The same applies to sound, where displacement will be greater at lower frequencies, because the velocity lasts longer during each half cycle.
Are both of those calculating power? Or just a decibel ratio of the amplitudes and sound pressures?
How is the power of a sound wave in decibels calculated from the amplitude of the wave?
If you have an electrical version of a sound, then it has come from a microphone. The microphone responds to either pressure or velocity, so the electrical power is proportional to the sound power (actually the power density of the sound in W/m2). Relative sound power is proportional to voltage squared, or 20 log V/Vref.
  • · Replies 42 ·
  • · Replies 18 ·
  • · Replies 32 ·
