Sound problem: Destructive Interference
The discussion centers on calculating the distance between two loudspeakers, A and B, to achieve destructive interference at a listener's position, C. The speakers emit a 68.6-Hz tone, and the speed of sound is 343 m/s. The initial approach involved using trigonometric relationships and setting up equations based on wavelength differences, ultimately arriving at a distance of 3.89 meters. However, a participant points out a potential error in the calculations and suggests employing the Law of Sines for a more straightforward solution. The conversation highlights the complexities of sound interference and the importance of accurate mathematical methods in solving such problems.
coconutgt
The drawing shows a loudspeaker A and point C, where a listeer is positioned. A second loudspeaker B is located somewhere to the right of A. Both speakers vibrate in phase and are playing a 68.6-Hz tone. The speed of sound is 343 m/s. What is the closest to speaker A that speaker B can be located, so that the listener hears no sound?
Picture:
First, I connected C and B to make a triangle. I then bisect the triangle with a line straight down from C to make 2 triangles (with the extra point being D). I call AB line = x and CD line = y. Next, I set up the destructive interference where the point in which line AB has to be 1 wavelength and line CB is half wavelength. So, the difference between AC and CB has to be
CB - CA = (n*wavelength)/2
for smallest distance, n would have to be 1.
with this, I list all the known and unknowns which are
AD = AC*cos(60)
DB = AB-AD -> x-cos(60)
CD = AC*sin(60)
CB = sqrt(sin^2(60)+ (x-cos^2(60)))
So then:
wavelength/2 = sqrt(sin^2(60)+cos^2(60) + x^2 - 2*cos(60x))
I solve to get:
x^2 - (2*cos(60)x) + (1 + wavelength^2/4)
use quadratic equation to get
x = 2.845 and x = -1.845
The correct answer is 3.89 m.
So, I don't know if I'm missing something here. I hope you guys can help. Thanks.
I can't say I followed all of your trig, but it looks to me like you said
CB = sqrt(sin^2(60)+ (x-cos^2(60))) = wavelength/2 = sqrt(sin^2(60)+cos^2(60) + x^2 - 2*cos(60x))
and that is not true
CB = CA + wavelength/2
You might consider using the Law of Sines to do this problem. CB is easy to find and you know angle CAB = 60°. Finding angle CBA and then angle ACB is easier with LoS than what you did.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
