Space Stuff and Launch Info
1,725 replies · 238K views
russ_watters said:
CNN has an article, but I feel like there should be more coverage of this. Seems like kind of a big deal.
https://www.cnn.com/2026/01/17/science/nasa-artemis-ii-moon-mission
It is kinda sad that not enough people are interested in space. Yeah, I know things are going off the rails in 2026 (AI stuff and wars) and would rather be in 2013, but this launch will be historic. Man, my TV will be on all day on February 6th to watch the launch. Hopefully, no mishaps. If the launch happened in any other decade like the 2010s or before, the news would be all over the launch for months.
https://arstechnica.com/space/2026/...rolls-to-launch-pad-but-key-test-looms-ahead/
Preparations for the first human spaceflight to the Moon in more than 50 years took a big step forward this weekend with the rollout of the Artemis II rocket to its launch pad.
Launch window calendar:
February 6, 7, 8, 10, 11
March 6, 7, 8, 9, 11
April 1, 3, 4, 5, 6, 30
Each day has a 120 minute launch window during the local night. You want a fixed orientation between launch site and direction of the Moon, which happens every ~25 hours. Artemis II will fly around new Moon, which leads to the monthly pattern. It also means the launch has to happen during the night. The "missing days" are an artifact of the 25 hour pattern (e.g. Feb 8, 11:20 pm -> Feb 10, 0:06 am).
Mission plan
ARB = apogee raise burn, the transition from a low Earth orbit to an eccentric orbit
USS = upper stage separation burn
PRB = perigee raise burn
TLI = trans-lunar injection, that's where they commit to going around the Moon
OTC/RTC = outbound/return trajectory correction maneuvers, small corrections to stay on the planned path.
PAO = public affairs office? Likely video calls with the crew. Here is one "PAO" from 2020.
The timing of the burns considers both orbital mechanics and the sleep schedule of the crew. PRB has to interrupt sleep, the trajectory correction maneuvers are chosen to not do that. Here is a detailed analysis.
Edit: Crew is now in quarantine
Amazon asks for an extension for its Kuiper/Leo constellation
They have launched 180 since April last year. Unsurprisingly, they won't reach 1600 by July this year. Amazon now wants this deadline to move by 2 years. They also bought 10 more Falcon 9 launches to speed up deployment as their other rockets are less available than planned.
Crew-12 has been moved from Feb 15 to Feb 11 to (slightly) shorten the time with only 3 people on the ISS. Assuming Artemis launches this month, it will become the shortest time between two crewed orbital spaceflights from the US. We might even see both rockets on their launch pads at the same time.
It will also be the first time a crew flies to the Moon and someone else is in space elsewhere. At the time of the Apollo program, all Soviet missions were short and none of them happened at the same time as a flight to the Moon.
10 hours 30 min
The poll to begin tanking will be in 10 min, if things go well then a small amount of propellant will be used to cool down everything starting in 20 minutes, and serious tanking will start in 1 hour 5 minutes.
NASA
NASA Spaceflight
The Launch Pad
This is only the WDR, but it will do everything short of igniting the engines. It'll be like the real launch except for the last few seconds (and without astronauts on board).
SLS is fully loaded, T-27 minutes. That's most of what we'll see externally, besides retracting the crew access arm at T-8 minutes.
At NSF commentators discussed that a successful launch of Artemis 2 will likely delay Crew-12 until the astronauts return, apparently NASA cannot or does not want to deal with two independent spaceflights at the same time.
Edit: There is also this issue with deorbiting an upper stage that SpaceX needs to understand before Crew-12 can fly.
There was a hydrogen leak in between, because there is always a hydrogen leak.
Edit: More holds, including an unplanned one at T-5 minutes. They are still working on some issues.
China successfully performed an in-flight abort test of Mengzhou, its next crewed capsule that will support both missions to LEO and to the Moon. It was also a landing test for Long March 10: Soft splashdown next to the ship that is expected to catch it in the future.
Vulcan Centaur launched another military satellite. There were a lot of sparks 65 seconds after launch. From a different perspective, it looks like there are already flames at the wrong spot 20 seconds after launch. ULA calls it "an observation".
If that reminds you of something, it's probably Vulcan's second flight. Pretty much the same pattern, also called an "observation". In that flight the nozzle of a solid rocket motor exploded. That's two SRB issues in four flights now, luckily neither one stopped the rocket from flying.
As it was a military launch, they stopped the telemetry while it was still flying, we don't know if it had enough performance to reach its target orbit. It's a launch to geosynchronous transfer orbit, which means the satellite is unlikely to have super strict requirements - it needs to raise its orbit a lot anyway.
At this rate, China might make it to the moon faster than Artemis. ;) Would be nice to see another nation arrive at the moon with a crewed spacecraft.
mfb said:
Second WDR for Artemis will start in ~12 hours - with fueling in two days.
NASA looked into options to launch a few days earlier, but the timeline is now leading to a launch no earlier than March 6 again (the start of the initial launch windows).
In other words, we have to wait for the moon to be in the right position to launch?
The Artemis WDR was successful, it reached the planned T-29s. There were some holds to address issues in between but all of them has been resolved fast enough - if this had been a launch attempt, it could have proceeded to launch.
Edit: NASA now aims at a launch on March 6 (March 7 by UTC).
NASA released the report on the Starliner Crewed Flight Test investigation. Full report (PDF, 311 pages)
NASA article, note sent to NASA employees
Article by Eric Berger
Jared Isaacman also gave a press conference, shown and discussed here by Ellie in Space. The mission is now classified as type A mishap, the worst type - Isaacman pointed out how this was overdue as the financial damage alone exceeded its threshold by a factor 100. He also heavily criticized how the Starliner program was handled in the past, and discussed how it will change (from NASA side) in the future. Boeing needs to actually identify the root cause of issues and fix it before this can fly people again. Sounds obvious, but that wasn't done in the past.
Doesn't look so good for Artemis.
After overnight data showed an interruption in helium flow in the SLS interim cryogenic propulsion stage, teams are troubleshooting and preparing for a likely rollback of Artemis II to the VAB at @NASAKennedy. This will almost assuredly impact the March launch window. @NASA will continue to provide updates as they become available.
This is something they discovered after the WDR. If they roll it back, we are looking at the April launch windows the earliest.
mfb said:
Yes, they want the far side to be in sunlight when they fly over it.
Fueling for WDR 2 is ongoing
Why do they want the far side in the sun? Couldn't a FLIR camera see the far side, without the need for it to be seen in visible light? Or do they want the far side to be in the sun to look better for us humans watching on Earth? Or even if the far side is partially lit
Seeing something is easier if the surface has sunlight. You can do infrared measurements either way, but there is no visible light without sunlight.
Rollback of Artemis II is underway
Mike Fincke has revealed that it was him with the "medical event" without saying what it was.
Edit: Expected, but now official: Space Force pauses national security launches on Vulcan until the SRB investigation is done and the Space Force is confident it won't happen again.
Edit: NASA shakes up leadership of human spaceflight program in wake of critical Starliner report
We see consequences of the Starliner report. The Space Operations Mission Directorate and the Commercial Crew Program get new leaders.
Isaacman has been busy. Besides the updates above, here is a 1 hour press conference on the future of Artemis
News coverage
For Artemis II, they'll have to inspect helium tanks, replace batteries of the flight termination system (FTS), and work more on leaks. To be determined how long that takes, but it doesn't sound like April.
Artemis III will not land on the Moon. It will stay in low Earth orbit and dock with one (or potentially both) landing vehicles, i.e. Starship and/or Blue Moon. Planned for 2027. It will test many aspects of the landers and potentially the space suits in a less risky environment, and it means refueling doesn't have to be ready yet.
NASA wants to launch Artemis IV in 2028 and land on the Moon with that. This means the new plan takes about as long as the old plan, but adds the low Earth orbit mission. NASA wants to increase the launch cadence of SLS/Orion significantly, to under one year between launches. They hope to launch Artemis V in 2028, too - but that means four launches within the next three years, which sounds extremely optimistic.
News coverage
Darn, so no moon landing for 2027? Patience is a virtue, as they say. Will the lunar space station be built?
Lunar Gateway Space Station:
https://www.nasa.gov/mission/gateway/
Gateway's status is unclear at the moment.
Firefly's Alpha rocket is back. After a launch failure last April, they reached orbit with a test flight - the third full success in 7 flights (2 failed to reach orbit, 2 reached a lower orbit).
Russia fixed its damaged launch pad, the next mission (cargo delivery to the ISS) is planned for March 22.
The first launch of Irtysh, or Soyuz-5, is planned for late March. 18 tonnes to orbit put it in the medium-lift category, but its first stages could become boosters for Yenisei (~100-140 tonnes to orbit).
Ignition: NASA's Plan for The Moon
1 hour press conference with Artemis updates.
Gateway is paused.
Neither SpaceX nor Blue Origin like NRHO (the distant Moon orbit that is a detour for landing on the surface), NASA considers alternatives. There are a couple of proposals. As an example, Starship could dock to Orion in Earth orbit and then push the combination to a low lunar orbit. Starship is so big that adding Orion doesn't change much, but avoiding NRHO saves a lot of propellant. It also means Starship can wait in Earth orbit instead of lunar orbit.
After the initial flights, NASA wants to land on the Moon every 6 months.
Two more updates will follow soon:
Ignition: NASA's Plan for Science and Discovery (in 2 hours)
Ignition: NASA News Conference (March 24, 2026) (in 6 hours)
L-42 hours. Orion should be powered up at this point, the rocket stages will follow shortly. Still on track for an April 1 launch, but with the option to launch at a later date if needed.
https://www.nasa.gov/general/nasa-releases-artemis-ii-moon-mission-launch-countdown/
https://www.nasa.gov/blogs/missions/2026/03/30/nasas-artemis-ii-launch-mission-countdown-begins/
We might see the launch of SLS, New Glenn (scheduled for April 10), Falcon Heavy (late April) and Starship (potentially late April) all in a single month. New Glenn will feature the first booster reuse that's not by SpaceX.
