OmCheeto
- 3,681
sophiecentaur said:1. Only a magnet can repel a permanent magnet, so you would need magnets on the track.
2. Stability would be a problem and the system would almost certainly flip you over on your back, painfully.
3. This effect would have to give a reasonable 'cushioning effect', over a distance of several cm. This could require seriously powerful magnets which would, even with the sexy new magnets available, involve a lot of weight. A spring to achieve the same thing would be much lighter and cheaper and would also be safer.
[Edit: that will teach me to read all the posts and you can disregard my point 1. The rest is ok though ]
Well, let's replace your point 1, with my point 4:
4. The equations don't work at shoe scale distances
OmCheeto said:You're welcome. And when it comes down to it, if I don't have the supplies lying around my house, and it's going to cost more than $20 to build, I always do the math first.
Also, the equation is obviously not valid for magnets that are extremely close to each other. As when the distance approaches zero, the repulsion tends towards infinity. And I know that is not correct, as I can with just a bit of effort, push two of my neodymium magnets together.
(1/8" length, 5/16" diameter)
At one micron separation, my magnets, according to the equation, should have a repulsion of about 190,000,000 Newtons*, which is a bit more than my thumb and index finger are capable of I'm sure.
*What is 190,000,000 Newtons equivalent to? The first stage of the Saturn V rocket had a thrust of only 34,000,000 Newtons. So a 190 megaNewtons is a lot!
So what do you do when the maths don't work?
I would do the experiment, and try and determine a curve fitting function for force vs small distances, but my magnets are too small to control, in a kitchen lab.
I did though do an experiment just now, with some 200 gram, 1970's era speaker magnets. I discovered that they were so weak, that when I placed one above the other, gravity won.
I did another experiment where my neodymiums floated in a plastic tube about 4 cm above the speaker magnets. I used a bamboo skewer to push the neo's down towards the speaker magnet. At around 5 millimeters, the repulsion was lost, and the neo's slammed into the speaker magnet.
hmmm... This is starting to look ugly on the human mass jumping shoe scale. And that's just the thoughts in my head. Just imagine what happens when you do the math.
hmmm... I wonder if Phil Knight had to put up with this negativity when he developed his air sole technology.
physicsfrenzy said:Its been over a year since I had thought of this idea and I had to revive this old topic to generate new discussion on my shoes. (no pun intended)
The reason why I revived this topic is now I have money to invest in a prototype pair to see if they do in fact work, and how the best effective way of doing so.
Just do it.
