Specific heat capacity & heat capacity
6 replies · 2K views
ellieee
what is the numerical value of the ratio ?
Q=mcθ
Q=mc
the answer is 1/2 , but when I did the working out, I got 2/1.. so I'm quite confused
Orodruin said:
The ratio has physical dimension. You therefore cannot assign a dimensionless numerical value.
then are you able to explain the answer key ?
Orodruin said:
But with regards to how the question (being ill posed) wants you to do things ...
You have taken heat capacity / specific heat capacity instead of specific heat capacity / heat capacity.
how ..? isn't specific heat capacity = mcθ and heat capacity = cθ?
No.
Specific capacity is ‘c’ (lower case ‘c’).
Heat capacity is ‘C’ (upper case ‘C’)
C = mc
Warning: it's easy to mix up 'c' and 'C'!
That means you are simply being asked to find ##\frac c {mc}##.
Other notes...
The question contains distractors - unnecessary information to test your ability to identify the relevant information.
Q=mcΔθ gives the heat transferred when an object of mass m and specific heat capacity c changes temperature by Δθ. It is not required in this question.
Q = CΔθ gives the heat transferred when an object of heat capacity C changes temperature by Δθ. It is not required in this question.
The correct answer should have units (as already noted by @Orodruin in Post #2).
Edit - typo' corrected.
